Assemble mqtt data to mysql
Hi there,
i am currently working on a private project by storing data of type number via mqtt into a mysql database.
The connection to mysql works, i have tested this with the inject node.
The sql insert command looks like this:
INSERT INTO mqtt-weather.temp
(timestamp,
value0)
VALUES
(<{timestamp: CURRENT_TIMESTAMP}>,<{value0: }>);
With this example payload I have successfully written to the sql database
(timestamp,
value0)
VALUES
(20200217180055,-2.1);
Now to my question proper:
How can i combine the data in node red with timestamp and value0 to pass the Insert Into command to the mysql node? (the mqtt channel returns only value0)
What would be the easiest and best way to reach the line??
In this respect I am a beginner and would very much like to learn!
Many thanks in advance.
Quito
If you always want to write the current time to that column then the best way is to create the timestamp column with a default of CURRENT_TIMESTAMP, then you don't need to provide a value for that column at all and mysql will automatically fill it in, so your query becomes
(timestamp)
VALUES
(-2.1);
If you don't want to do that then you can use NOW() so the query is
(timestamp,
value0)
VALUES
(NOW(),-2.1);
Hey, Colin both ways are great :+1: Thanks
the mqtt channel returns only value0 as type number.
What would be the best way to integrate it? Via a function node ?
I like to build my queries in a template node something like this
SELECT * FROM wp_users
where user_login = '{{payload}}';
Either a function node or a template (not ui template) node. The template node may be considered simpler. The info tab for the node gives some examples that should let you do it. Don't forget to set the Property field to msg.topic.
Template Node leike this..? payload set to value0
temp (timestamp, value0)
VALUES (NOW(),{{value0}});
If the MQTT node returns only the value, it should be in msg.payload. In that case you should use
VALUES (NOW(),{{payload}});
because the value is in msg.payload
Hi Colin, Hi zenofmud,
I thank you both because it's working out like I thought. Super
