Good morning everyone, I apologize for my English, I used a translator. I am trying to configure my Audac MTX48 device using Node-RED in Home Assistant by sending TCP commands, but I am encountering the following problems:
- I have configured everything according to the manual (https://www.acpromedia.com/assets/uploads/product_downloads/bc16f4a50678d0387d5ae25b408f9eb7.pdf).
- Using the Pocket Sender application, the commands work correctly.
- Using Node-RED, they do not work
Node-RED Settings
INJECT msg.payload = #|X001|web|SM01|1|U|r\n (string)
TCP OUT Connect to port 5001 at host 10.0.0.253 I tried both with and without “Close connection after each message is sent?”
DEBUG 15/06/2024, 07:30:13
node: debug 1
msg.payload : string[23]
“#|X001|web|SM01|1|U|r/n”
NODE-RED APP LOG
15 Jun 07:54:28 - [info] [debug:debug 1] #|X001|web|SM01|1|U|r/n
15 Jun 07:54:28 - [info] [tcp out:2] connecting to 10.0.0.253:5001
15 Jun 07:54:28 - [info] [tcp out:2] connected to 10.0.0.253:5001
- I tried to ping from Node-RED to 10.0.0.253 (Audac) and it works correctly.
How can I resolve the problem? I have also searched the forum but found no solutions.
Thank you for your help.
