Hi, I am trying to expose some endpoints (api) for this I want to add authentication, I can able to add bais auth by enabling httpNodeAuth in the settings.js file but I want to pass authorization(access_token) in the header which I usually get from auth/token this endpoint, how can do this?
You want to send or receive information in the http headers?
If you wish to send see the cookbook. https://cookbook.nodered.org where there’s an example.
If you wish to receive they are included in the msg object. Add a debug node set to display complete message.
@ukmoose I want to pass Authorization in header,
example: i have two apis localhost:1880/auth/token - here i am getting access_token, this token i want to pass as Authorization for localhost:1880/hello this get api
