I try to authenticate admins based on a header variable (with Nodered 1.1.3). If a token is present i query the LDAP for authentication. If in LDAP the user is not authorized, I resolve the user to null.
Actually in this case, I want to offer user/Password based authentication. But the user/password dialog is here no longer present, so I can only see the logo in the left corner, the header and the rest is blank.
Is this way of failover-authentication even possible? Is resolve user to null the correct way or how can I return with the token function that user/password authentication is tried?
@knolleary Hey Nick, can you take a look on this topic and give me a little hint?
How exactly have you got adminAuth configured?
I have a configuration like this (I tried to trivialize it a little):
module.exports = {
type: "credentials",
users: function(username) {
return new Promise(function(resolve) {
// Do whatever work is needed to check username is a valid
// user.
if (valid) {
// Resolve with the user object. It must contain
// properties 'username' and 'permissions'
var user = { username: "admin", permissions: "*" };
resolve(user);
} else {
// Resolve with null to indicate this user does not exist
resolve(null);
authenticate: function(username,password) {
// Do whatever work is needed to validate the username/password
// combination.
if (valid) {
// Resolve with the user object. Equivalent to having
// called users(username);
resolve(user);
} else {
// Resolve with null to indicate the username/password pair
// were not valid.
resolve(null);
default: function() {
return when.promise(function(resolve) {
// Resolve with the user object for the default user.
resolve({anonymous: true, permissions:"read"});
tokenHeader: "RVUSER",
tokens: function(token) {
return new Promise(function(resolve, reject) {
// Do whatever work is needed to check token is valid
if (valid) {
var user = { username: 'admin', permissions: '*' };
resolve(user);
} else {
// Resolve with null as this user does not exist
// We expect that user-password instead is tried
resolve(null);
