Hi everyone!
Is it possible to generate custom authentication token when authenticating via OAuth protocol?
I tried to implement custom settings.adminAuth.authenticate() function, as suggested in this topic , but it doesn't seem to work with settings.adminAuth.type = 'strategy'.
What i am trying to achieve is to use multiple Node-Red instances behind Nginx Load Balancer.
So generating JWT Token after OAuth2 Authentication and later checking it with settings.adminAuth.tokens would have been an acceptable solution.
I understand that this setup won't let me use all Node-Red Admin UI features (deploy, debug panel, etc) , but this is fine, because i have separate dev instance , and then flows.json is deployed across this self-made 'cluster', so here UI is used mainly for informational purposes.
Thanks in advance!
