Is there a way to make my Pi auto-login to my dashboard? Basically if the dashboard is accessed from my Pi (where node-red is located) it will bypass the authentication.
I think you could probably do that with a custom authentication (see the settings.js file for the property that controls that) but no, not natively.
We do not support custom authentication for the Dashboard - only for the editor.
Badly worded as usual. I meant:
// The following property can be used to add a custom middleware function
// in front of all http in nodes. This allows custom authentication to be
// applied to all http in nodes, or any other sort of common request processing.
//httpNodeMiddleware: function(req,res,next) {
// // Handle/reject the request, or pass it on to the http in node by calling next();
// // Optionally skip our rawBodyParser by setting this to true;
// //req.skipRawBodyParser = true;
// next();
// The following property can be used to verify websocket connection attempts.
// This allows, for example, the HTTP request headers to be checked to ensure
// they include valid authentication information.
//webSocketNodeVerifyClient: function(info) {
// 'info' has three properties:
// - origin : the value in the Origin header
// - req : the HTTP request
// - secure : true if req.connection.authorized or req.connection.encrypted is set
// The function should return true if the connection should be accepted, false otherwise.
// Alternatively, if this function is defined to accept a second argument, callback,
// it can be used to verify the client asynchronously.
// The callback takes three arguments:
// - result : boolean, whether to accept the connection or not
// - code : if result is false, the HTTP error status to return
// - reason: if result is false, the HTTP reason string to return
Don't they work with Dashboard?
No, httpNodeMiddleware only applies to the HTTP In nodes.
And node-red-contrib-uibuilder
