Please guide regarding performing average of 4 data coming from sensor using function node.
I have tried something as below.
var val1 = parseInt(flow.get("val1"));
msg.payload = parseInt(flow.get("val2")) + val1;
maybe use the smooth node set to handle 4 messages, if they are just continuously arriving data ? (rather than using flow variables nad aving to manage them).
Thank you for the reply!
No it's not continuously arriving. When ever I will press button on dashboard data will be received.
I am not able to deal with var newMsg = { payload: msg.payload,topic:msg.Agg1 }; or I am not sure
about I have done any mistake with change node.
[{"id":"1d93d5ed.92f58a","type":"change","z":"2349502c.99c05","name":"set topic to agg1","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg1","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"payload[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":800,"wires":[["5fc5654e.601e1c","19d4c554.eb8b2b"]],"_type":"node"},{"id":"a9f2abc.c32c658","type":"change","z":"2349502c.99c05","name":"set topic to agg2","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg2","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"payload[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":920,"wires":[["1694954b.2bbbab","19d4c554.eb8b2b"]]},{"id":"7026f7e.c6e0808","type":"change","z":"2349502c.99c05","name":"","rules":[{"t":"set","p":"val1","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1080,"wires":[["108dd60d.a6f95a"]]},{"id":"11d47184.5b5cce","type":"change","z":"2349502c.99c05","name":"","rules":[{"t":"set","p":"val2","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1160,"wires":[["108dd60d.a6f95a"]]},{"id":"1694954b.2bbbab","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1030,"y":980,"wires":[]},{"id":"5fc5654e.601e1c","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1030,"y":760,"wires":[]},{"id":"7fd74dbb.3c7404","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1263.5,"y":862.97265625,"wires":[]},{"id":"1e4fa120.019a0f","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":967.50390625,"y":1240.98046875,"wires":[]},{"id":"1e7ec413.c5e2bc","type":"extract parameter","z":"2349502c.99c05","name":"Agg1_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg1_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspect\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variable\":\"te977db91a139c\",\"variableName\":\"Agg1_Current_Weight\"}","parameter":"Agg1_Current_Weight","x":620,"y":800,"wires":[["1d93d5ed.92f58a","7026f7e.c6e0808"]]},{"id":"76a15ec5.0ad2d","type":"extract parameter","z":"2349502c.99c05","name":"Agg2_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg2_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspect\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variable\":\"tf977db91a139d\",\"variableName\":\"Agg2_Current_Weight\"}","parameter":"Agg2_Current_Weight","x":620,"y":920,"wires":[["a9f2abc.c32c658","11d47184.5b5cce"]]},{"id":"108dd60d.a6f95a","type":"function","z":"2349502c.99c05","name":"add","func":"var val1 = parseInt(flow.get(\"val1\"));\nmsg.payload = parseInt(flow.get(\"val2\")) + val1;\nreturn msg;","outputs":1,"language":"javascript","noerr":0,"x":790,"y":1120,"wires":[["9884e4a1.5dfbe8","1e4fa120.019a0f"]]},{"id":"19d4c554.eb8b2b","type":"function","z":"2349502c.99c05","name":"","func":"var newMsg = { payload: msg.payload,topic:msg.Agg1 };\nreturn newMsg;","outputs":1,"language":"javascript","noerr":0,"x":1060,"y":860,"wires":[["7fd74dbb.3c7404"]],"_type":"node"},{"id":"381866a2.57779a","type":"read timeseries","z":"2349502c.99c05","name":"Agg1_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg1_Current_Weight","topicLabel":"BatchMix/BatchMix_Current_Weight/Agg1_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspects\":[{\"aspectId\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variables\":[{\"variableId\":\"te977db91a139c\",\"name\":\"Agg1_Current_Weight\"}]}]}","assetName":"","selectedTopics":"","period":"60","offset":"0","mode":"lastValue","from":"","datetimepickerFrom":"","to":"","datetimepickerTo":"","timezoneoffset":0,"x":380,"y":800,"wires":[["1e7ec413.c5e2bc"]]},{"id":"4026ec1d.ffbf64","type":"read timeseries","z":"2349502c.99c05","name":"Agg2_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg2_Current_Weight","topicLabel":"BatchMix/BatchMix_Current_Weight/Agg2_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspects\":[{\"aspectId\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variables\":[{\"variableId\":\"tf977db91a139d\",\"name\":\"Agg2_Current_Weight\"}]}]}","assetName":"","selectedTopics":"","period":"60","offset":"0","mode":"lastValue","from":"","datetimepickerFrom":"","to":"","datetimepickerTo":"","timezoneoffset":0,"x":380,"y":920,"wires":[["76a15ec5.0ad2d"]]},{"id":"bd83ce8.c13c63","type":"ui_button","z":"2349502c.99c05","name":"","group":"933bef30.6e133","order":0,"width":0,"singleBrowser":false,"height":0,"passthru":false,"label":"button_Average","color":"","bgcolor":"","icon":"","payload":"[65]","payloadType":"json","topic":"","powerMode":false,"x":160,"y":860,"wires":[["381866a2.57779a","4026ec1d.ffbf64"]]},{"id":"9884e4a1.5dfbe8","type":"ui_text","z":"2349502c.99c05","group":"933bef30.6e133","order":3,"width":0,"singleBrowser":false,"height":0,"name":"","label":"Result","format":"{{msg.payload}}","layout":"row-spread","x":970,"y":1120,"wires":[]},{"id":"933bef30.6e133","type":"ui_group","z":"","name":"Summation","tab":"71bf6668.e36f88","order":2,"disp":true,"width":"6","collapse":false,"_type":"config"},{"id":"71bf6668.e36f88","type":"ui_tab","z":"","name":"PLANT1","icon":"dashboard","order":3,"publicAccess":"true","fmAccess":"default","fmAccessType":"public","assetType":"","asset":"","assetName":"","assetText":"","image":"","description":"","hideTitleBar":false,"_type":"config"}]```
You could use array.reduce()
e.g.
let vals = flow.get(["val1","val2","val3","val4"]);
let count = 0
msg.payload = vals.reduce((acc, str) => {
let num = parseFloat(str);
if(!isNaN(num)){
acc+=num;
count++;
return acc;
},0) / count
Thank you so much.
Sorry for bothering but please can you guide me from the basic. I have read about function node. but still not able to perform simple things like an average.
I am stuck here, var newMsg = { payload: msg.payload,topic:msg.Agg1 };
now I don't know how to get that particular value (like 88.18,[296.64]) from the change node and then use it in function node.
It would be great help If you can guide me about how can I learn to do these stuffs.
In the first post what I have posted was done by someone else, I have just taken it from one site.
Sorry - by continuously I meant all the data arriving down the same pipe... so yes sounds like it does to me as the format of the data will be the same every time you click the button. So the smooth node should be able to operate on it for you.
If you want to average the incoming Agg's then @dceejay smooth node suggestion should work.
e.g.
[{"id":"91ed3404248ead63","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":610,"y":2140,"wires":[["3948c6524f476f07"]]},{"id":"3948c6524f476f07","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2280,"wires":[["55361aab2126a937"]]},{"id":"be942040732bbd1b","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":610,"y":2180,"wires":[["3948c6524f476f07"]]},{"id":"4a62b512e2b2df5d","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":610,"y":2220,"wires":[["3948c6524f476f07"]]},{"id":"55361aab2126a937","type":"smooth","z":"452103ea51141731","name":"","property":"payload","action":"mean","count":"4","round":"","mult":"multi","reduce":false,"x":520,"y":2340,"wires":[["b55467f3.7db4a8"]]},{"id":"c6335dab10297ba2","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2400,"wires":[["55361aab2126a937"]]},{"id":"b55467f3.7db4a8","type":"switch","z":"452103ea51141731","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"100","vt":"str"},{"t":"gt","v":"400","vt":"str"},{"t":"btwn","v":"101","vt":"num","v2":"399","v2t":"num"}],"checkall":"true","outputs":3,"x":670,"y":2340,"wires":[["0e73504f05b83fe1"],["935bee49935fc29e"],["b894775069327319"]]},{"id":"3e04b86e4866ba3c","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"300","payloadType":"num","x":590,"y":2460,"wires":[["c6335dab10297ba2"]]},{"id":"af2f1c3d3ab3ccea","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":590,"y":2500,"wires":[["c6335dab10297ba2"]]},{"id":"d707d97320850531","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":590,"y":2540,"wires":[["c6335dab10297ba2"]]},{"id":"0e73504f05b83fe1","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Value at low stage {{payload}}","output":"str","x":820,"y":2280,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"935bee49935fc29e","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Value at high stage {{payload}}","output":"str","x":820,"y":2320,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"b894775069327319","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Status:OK {{payload}}","output":"str","x":820,"y":2360,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"2886ab01.99ebd4","type":"debug","z":"452103ea51141731","name":"","active":false,"console":"false","complete":"false","x":1050,"y":2380,"wires":[]},{"id":"282f48fec86a2064","type":"join","z":"452103ea51141731","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1030,"y":2320,"wires":[["aa11dc31892f3b98"]]},{"id":"aa11dc31892f3b98","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"1:{{payload.Agg1}}<br>\n2:{{payload.Agg2}}<br> ","output":"str","x":1180,"y":2320,"wires":[["608f6c08.c056e4"]]},{"id":"608f6c08.c056e4","type":"debug","z":"452103ea51141731","name":"","active":true,"console":"false","complete":"false","x":1350,"y":2320,"wires":[]}]
Actually, I am not using node-red. I am using mindsphere's api, visual flow creator where I can not download smooth node.
mindsphere have a community forum
To answer the question then you would have to implement the function of the smooth node in a function node.
[{"id":"91ed3404248ead63","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":610,"y":2140,"wires":[["3948c6524f476f07"]]},{"id":"3948c6524f476f07","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2280,"wires":[["0eb9731f3ac45f34"]]},{"id":"be942040732bbd1b","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":610,"y":2180,"wires":[["3948c6524f476f07"]]},{"id":"4a62b512e2b2df5d","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":610,"y":2220,"wires":[["3948c6524f476f07"]]},{"id":"0eb9731f3ac45f34","type":"function","z":"452103ea51141731","name":"function 16","func":"const average_count = 4;\nlet vals = context.get(\"average_array.\" + msg.topic) || [];\nvals.push(msg.payload)\nvals = vals.slice(-average_count);\nmsg.payload = vals.reduce((acc, str) => {\n let num = parseFloat(str);\n if(!isNaN(num)){\n acc+=num;\n }\n return acc;\n},0) / vals.length\ncontext.set(\"average_array.\" + msg.topic, vals)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":2340,"wires":[["b55467f3.7db4a8"]]},{"id":"c6335dab10297ba2","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2400,"wires":[["0eb9731f3ac45f34"]]},{"id":"b55467f3.7db4a8","type":"switch","z":"452103ea51141731","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"100","vt":"str"},{"t":"gt","v":"400","vt":"str"},{"t":"btwn","v":"101","vt":"num","v2":"399","v2t":"num"}],"checkall":"true","outputs":3,"x":670,"y":2340,"wires":[["0e73504f05b83fe1"],["935bee49935fc29e"],["b894775069327319"]]},{"id":"3e04b86e4866ba3c","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"300","payloadType":"num","x":590,"y":2460,"wires":[["c6335dab10297ba2"]]},{"id":"af2f1c3d3ab3ccea","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":590,"y":2500,"wires":[["c6335dab10297ba2"]]},{"id":"d707d97320850531","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":590,"y":2540,"wires":[["c6335dab10297ba2"]]},{"id":"0e73504f05b83fe1","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Value at low stage {{payload}}","output":"str","x":820,"y":2280,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"935bee49935fc29e","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Value at high stage {{payload}}","output":"str","x":820,"y":2320,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"b894775069327319","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{topic}}: Status:OK {{payload}}","output":"str","x":820,"y":2360,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"2886ab01.99ebd4","type":"debug","z":"452103ea51141731","name":"","active":false,"console":"false","complete":"false","x":1050,"y":2380,"wires":[]},{"id":"282f48fec86a2064","type":"join","z":"452103ea51141731","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1030,"y":2320,"wires":[["aa11dc31892f3b98"]]},{"id":"aa11dc31892f3b98","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"1:{{payload.Agg1}}<br>\n2:{{payload.Agg2}}<br> ","output":"str","x":1180,"y":2320,"wires":[["608f6c08.c056e4"]]},{"id":"608f6c08.c056e4","type":"debug","z":"452103ea51141731","name":"","active":true,"console":"false","complete":"false","x":1350,"y":2320,"wires":[]}]
let vals = context.get("average_array." + msg.topic) || [];
if(!isNaN(num)){
acc+=num;
return acc;
},0) / vals.length
context.set("average_array." + msg.topic, vals)
Thank you so much. I will try to deal with smooth node.
but wait Sorry, I think there is miscommunication. I am trying to do (a+b)/2 kind of thing.
I have tried something but there is some issue. It does not return any value.
[{"id":"bd83ce8.c13c63","type":"ui_button","z":"2349502c.99c05","name":"","group":"933bef30.6e133","order":0,"width":0,"singleBrowser":false,"height":0,"passthru":false,"label":"button_Average","color":"","bgcolor":"","icon":"","payload":"[65]","payloadType":"json","topic":"","powerMode":false,"x":160,"y":860,"wires":[["381866a2.57779a","4026ec1d.ffbf64"]]},{"id":"381866a2.57779a","type":"read timeseries","z":"2349502c.99c05","name":"Agg1_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg1_Current_Weight","topicLabel":"BatchMix/BatchMix_Current_Weight/Agg1_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspects\":[{\"aspectId\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variables\":[{\"variableId\":\"te977db91a139c\",\"name\":\"Agg1_Current_Weight\"}]}]}","assetName":"","selectedTopics":"","period":"60","offset":"0","mode":"lastValue","from":"","datetimepickerFrom":"","to":"","datetimepickerTo":"","timezoneoffset":0,"x":380,"y":800,"wires":[["1e7ec413.c5e2bc"]]},{"id":"4026ec1d.ffbf64","type":"read timeseries","z":"2349502c.99c05","name":"Agg2_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg2_Current_Weight","topicLabel":"BatchMix/BatchMix_Current_Weight/Agg2_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspects\":[{\"aspectId\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variables\":[{\"variableId\":\"tf977db91a139d\",\"name\":\"Agg2_Current_Weight\"}]}]}","assetName":"","selectedTopics":"","period":"60","offset":"0","mode":"lastValue","from":"","datetimepickerFrom":"","to":"","datetimepickerTo":"","timezoneoffset":0,"x":380,"y":920,"wires":[["76a15ec5.0ad2d"]]},{"id":"1e7ec413.c5e2bc","type":"extract parameter","z":"2349502c.99c05","name":"Agg1_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg1_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspect\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variable\":\"te977db91a139c\",\"variableName\":\"Agg1_Current_Weight\"}","parameter":"Agg1_Current_Weight","x":620,"y":800,"wires":[["1d93d5ed.92f58a"]]},{"id":"76a15ec5.0ad2d","type":"extract parameter","z":"2349502c.99c05","name":"Agg2_Current_Weight","topic":"1a655a707b4a445a98eb4f4e516b02a0/BatchMix_Current_Weight/Agg2_Current_Weight","topicData":"{\"asset\":\"1a655a707b4a445a98eb4f4e516b02a0\",\"assetName\":\"BatchMix\",\"aspect\":\"cde53ccd1ff84624af95951d5dc41188\",\"aspectName\":\"BatchMix_Current_Weight\",\"variable\":\"tf977db91a139d\",\"variableName\":\"Agg2_Current_Weight\"}","parameter":"Agg2_Current_Weight","x":620,"y":920,"wires":[["a9f2abc.c32c658"]]},{"id":"1d93d5ed.92f58a","type":"change","z":"2349502c.99c05","name":"set topic to agg1","rules":[{"t":"set","p":"topic","pt":"msg","to":"task1","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"payload[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":800,"wires":[["5fc5654e.601e1c","62707696.611158"]],"_type":"node"},{"id":"a9f2abc.c32c658","type":"change","z":"2349502c.99c05","name":"set topic to agg2","rules":[{"t":"set","p":"topic","pt":"msg","to":"task2","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"payload[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":920,"wires":[["1694954b.2bbbab","62707696.611158"]],"_type":"node"},{"id":"5fc5654e.601e1c","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1030,"y":760,"wires":[]},{"id":"62707696.611158","type":"function","z":"2349502c.99c05","name":"","func":"context.data= context.data ||{};\nswitch(msg.topic){\n case \"task1\":\n context.data.task1 = msg.payload;\n msg=null;\n break;\n case \"task2\":\n context.data.task2 = msg.payload;\n msg=null;\n break;\n default:\n msg=null;\n break;\n}\n\nif(context.data.task1 !=null && context.data.task2 !=null){\n var Avg=(context.data.task1/context.data.task2)/2;\n context.data=null;\n return{payload:ratio};\n}else return msg;\n","outputs":1,"language":"javascript","noerr":0,"x":1020,"y":860,"wires":[["d8d7a10a.262fb","e4af3fa8.055d1"]],"_type":"node"},{"id":"1694954b.2bbbab","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1030,"y":980,"wires":[]},{"id":"e4af3fa8.055d1","type":"ui_text","z":"2349502c.99c05","group":"933bef30.6e133","order":0,"width":0,"singleBrowser":false,"height":0,"name":"","label":"text","format":"{{msg.payload}}","layout":"row-spread","x":1210,"y":900,"wires":[],"_type":"node"},{"id":"d8d7a10a.262fb","type":"debug","z":"2349502c.99c05","name":"","active":true,"console":"false","xaxis":"","complete":"payload","x":1233.890625,"y":842.97265625,"wires":[],"_type":"node"},{"id":"933bef30.6e133","type":"ui_group","z":"","name":"Summation","tab":"71bf6668.e36f88","order":2,"disp":true,"width":"6","collapse":false,"_type":"config"},{"id":"71bf6668.e36f88","type":"ui_tab","z":"","name":"PLANT1","icon":"dashboard","order":3,"publicAccess":"true","fmAccess":"default","fmAccessType":"public","assetType":"","asset":"","assetName":"","assetText":"","image":"","description":"","hideTitleBar":false,"_type":"config"}]
you originally said average over 4 ... now you say 2... sorry - mind reading is not one our key skills
. In E1cid's example change the 4 to a 2...
If there has been miscommunication, then you need to explain your issue more clearly, I asked if you wanted to average the incoming Agg's in a previous post, you did not reply no.
Just incase you want to average of Agg1 + Agg2, this example shows how. The templates now output objects not strings.
[{"id":"91ed3404248ead63","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":610,"y":2140,"wires":[["3948c6524f476f07"]]},{"id":"3948c6524f476f07","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2280,"wires":[["b55467f3.7db4a8"]]},{"id":"be942040732bbd1b","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":610,"y":2180,"wires":[["3948c6524f476f07"]]},{"id":"4a62b512e2b2df5d","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":610,"y":2220,"wires":[["3948c6524f476f07"]]},{"id":"b55467f3.7db4a8","type":"switch","z":"452103ea51141731","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"100","vt":"str"},{"t":"gt","v":"400","vt":"str"},{"t":"btwn","v":"101","vt":"num","v2":"399","v2t":"num"}],"checkall":"true","outputs":3,"x":670,"y":2340,"wires":[["0e73504f05b83fe1"],["935bee49935fc29e"],["b894775069327319"]]},{"id":"c6335dab10297ba2","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Agg2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":2400,"wires":[["b55467f3.7db4a8"]]},{"id":"0e73504f05b83fe1","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n \"string\": \"{{topic}}: Value at low stage {{payload}}\",\n \"value\": {{payload}}\n}","output":"json","x":820,"y":2280,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"935bee49935fc29e","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n \"string\": \"{{topic}}: Value at high stage {{payload}}\",\n \"value\": {{payload}}\n}","output":"json","x":820,"y":2320,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"b894775069327319","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n \"string\": \"{{topic}}: Status:OK {{payload}}\",\n \"value\": {{payload}}\n}","output":"json","x":820,"y":2360,"wires":[["2886ab01.99ebd4","282f48fec86a2064"]]},{"id":"3e04b86e4866ba3c","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"300","payloadType":"num","x":590,"y":2460,"wires":[["c6335dab10297ba2"]]},{"id":"af2f1c3d3ab3ccea","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":590,"y":2500,"wires":[["c6335dab10297ba2"]]},{"id":"d707d97320850531","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":590,"y":2540,"wires":[["c6335dab10297ba2"]]},{"id":"2886ab01.99ebd4","type":"debug","z":"452103ea51141731","name":"","active":false,"console":"false","complete":"false","x":1050,"y":2380,"wires":[]},{"id":"282f48fec86a2064","type":"join","z":"452103ea51141731","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1030,"y":2320,"wires":[["608f6c08.c056e4","196bd4e711ea2aeb"]]},{"id":"608f6c08.c056e4","type":"debug","z":"452103ea51141731","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":790,"y":2540,"wires":[]},{"id":"196bd4e711ea2aeb","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"payload.average","pt":"msg","to":"$average($$.payload.*.value)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":2260,"wires":[["aa11dc31892f3b98"]]},{"id":"aa11dc31892f3b98","type":"template","z":"452103ea51141731","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"1:{{payload.Agg1.string}}<br>\n2:{{payload.Agg2.string}}<br> \nAverage: {{payload.average}}","output":"str","x":1180,"y":2320,"wires":[["608f6c08.c056e4"]]}]
I apologize for the inconvenience caused and thank you for the help!
