Hi all,
Is there a simple way to have a background image (on a group, a tab, or just in a ui_template node) on which I overlay a few ui_text nodes?
Thought this would be easy with node-red-dashboard, but after some searching I'm getting scared that I need to create my own widget, or move to a different front-end stack.
I have a simple 2D image of my water heating system, and want to display the temperature values 'on-top' of it. Guess that is a common use case.
thanks a ton!
bram
It is doable (I've seen screenshots of dashboard with background images on tabs and groups)
Did you search this forum for background image?
I stopped counting after scrolling past 50 potential answers.
The answer is definitely there.
If you give it a go & get stuck, I'm certain someone will help out.
You are right, it's there.
I'm sure this is not the right way to do it. but works for me:
<style>
#Groupname_Tagname {
background-image: url("myimage.jpg");
body.nr-dashboard-theme md-content md-card {
background: transparent;
color: white !important
</style>
cheers, bram
