Bad data inject updating chart
Not sure if that is a JSON string or a JS object, so i have shown both.
This should work
[{"id":"1b8d20ef646f7cb1","type":"debug","z":"d1395164b4eec73e","name":"debug 2480","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":290,"y":5900,"wires":[]},{"id":"605ffd7b41ce670f","type":"function","z":"d1395164b4eec73e","name":"function 1","func":"// Set the payload for the dashboard\nmsg.payload = {\n   'DS18B20 Temperature':  msg.payload.temperature_ds18b20 ,\n   'DHT11 Temperature': msg.payload.temperature_dht11,\n   'DHT11 Humidity': msg.payload.humidity_dht11\n};\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":6000,"wires":[["1aa37e9c314c7eb9","141cc79c43fb618a","bc4d48857a5a183d","95d0e3b97b3b42a0","1b8d20ef646f7cb1"]]},{"id":"802cd4bd9660557c","type":"inject","z":"d1395164b4eec73e","name":"pico input js object","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"temperature_ds18b20\": 66.9875, \"sensor_type\": \"sensor_data\", \"temperature_dht11\": 68.0, \"humidity_dht11\": 48, \"timestamp\": \"2021-01-04 02:06:26\"}","payloadType":"json","x":170,"y":6000,"wires":[["605ffd7b41ce670f"]]},{"id":"77825a88417f053a","type":"json","z":"d1395164b4eec73e","name":"","property":"payload","action":"","pretty":false,"x":330,"y":6060,"wires":[["605ffd7b41ce670f"]]},{"id":"1aa37e9c314c7eb9","type":"ui_gauge","z":"d1395164b4eec73e","name":"","group":"31b7bf6762bf2608","order":5,"width":0,"height":0,"gtype":"gage","title":"DS18B20 Temperature Bottom of Tank","label":"Fahrenheit","format":"{{msg.payload[\"DS18B20 Temperature\"] | number : 2}} °F","min":"60","max":"80","colors":["#00b500","#e6e600","#ca3838"],"seg1":"75","seg2":"76","diff":false,"className":"","x":750,"y":5900,"wires":[]},{"id":"141cc79c43fb618a","type":"ui_gauge","z":"d1395164b4eec73e","name":"","group":"31b7bf6762bf2608","order":1,"width":0,"height":0,"gtype":"gage","title":"DHT11 Temperature","label":"Fahrenheit","format":"{{msg.payload[\"DHT11 Temperature\"] | number : 0}} °F","min":"60","max":"80","colors":["#00b500","#e6e600","#ca3838"],"seg1":"75","seg2":"76","diff":false,"className":"","x":700,"y":5980,"wires":[]},{"id":"bc4d48857a5a183d","type":"ui_gauge","z":"d1395164b4eec73e","name":"","group":"31b7bf6762bf2608","order":3,"width":0,"height":0,"gtype":"gage","title":"DHT11 Humidity","label":"Percent","format":"{{msg.payload[\"DHT11 Humidity\"] | number   : 0}} %","min":"40","max":"90","colors":["#00b500","#e6e600","#ca3838"],"seg1":"60","seg2":"80","diff":false,"className":"","x":680,"y":5940,"wires":[]},{"id":"95d0e3b97b3b42a0","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":550,"y":6100,"wires":[["5a3f24530de6c96d"]]},{"id":"a1a0cbe8812e114a","type":"inject","z":"d1395164b4eec73e","name":"pico input json string","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"temperature_ds18b20\": 66.9875, \"sensor_type\": \"sensor_data\", \"temperature_dht11\": 68.0, \"humidity_dht11\": 48, \"timestamp\": \"2021-01-04 02:06:26\"}","payloadType":"str","x":170,"y":6060,"wires":[["77825a88417f053a"]]},{"id":"5a3f24530de6c96d","type":"ui_chart","z":"d1395164b4eec73e","name":"","group":"31b7bf6762bf2608","order":5,"width":0,"height":0,"label":"historical Data","chartType":"line","legend":"true","xformat":"auto","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"60","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":720,"y":6100,"wires":[["d982a6320b91f6fc"]]},{"id":"d982a6320b91f6fc","type":"debug","z":"d1395164b4eec73e","name":"chart data","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":940,"y":6040,"wires":[]},{"id":"31b7bf6762bf2608","type":"ui_group","name":"Dougie's Temp and Humidity","tab":"6d10beb5c3a6b93b","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"6d10beb5c3a6b93b","type":"ui_tab","name":"Douglas's Tank Metrics","icon":"dashboard","disabled":false,"hidden":false}]
Click legend to remove and add lines in chart.
