Unable to use - node-red-dashboard-2-ui-flowviewer
Hi - I see a new node released
I have successfully managed to install it.
I took one of my existing flows.json and sent it via. msg.ui_update.flow
I took one of the flows into a json and sent it via. msg.ui_update.flow
I tried put them into these into the nodes - input.
None of the options work.
The dashboard simply doesnt show the flow.
Works fine for me.
chrome_XtFzUNKHvj
Can you post a simple flow that exhibits the problem? Put a short flow in an Inject node, or setup the flow in a function node if that is easier for you, and export that with the flowviewer node and paste here. Then we can try it for ourselves.
Please find details
Snapshot of flow
Snapshot of inject node
Snapshof what is being injected.
Flow itself
        "id": "4215629d9434a8d0",
        "type": "ui-flowviewer",
        "z": "8c51c2e3b8be9323",
        "name": "Flow Viewer",
        "group": "f7474bf3bc523d1c",
        "order": 1,
        "width": "17",
        "flow": "[     {         \"id\": \"442b5c2b006f3093\",         \"type\": \"tab\",         \"label\": \"Test flow\",         \"disabled\": false,         \"info\": \"\",         \"env\": []     },     {         \"id\": \"a4083f2cf9cbb97e\",         \"type\": \"inject\",         \"z\": \"442b5c2b006f3093\",         \"name\": \"\",         \"props\": [             {                 \"p\": \"payload\"             },             {                 \"p\": \"topic\",                 \"vt\": \"str\"             }         ],         \"repeat\": \"\",         \"crontab\": \"\",         \"once\": false,         \"onceDelay\": 0.1,         \"topic\": \"\",         \"payload\": \"\",         \"payloadType\": \"date\",         \"x\": 320,         \"y\": 160,         \"wires\": [             [                 \"9d436e020a6768f9\"             ]         ]     },     {         \"id\": \"9d436e020a6768f9\",         \"type\": \"function\",         \"z\": \"442b5c2b006f3093\",         \"name\": \"function 2\",         \"func\": \"\\nreturn msg;\",         \"outputs\": 1,         \"timeout\": 0,         \"noerr\": 0,         \"initialize\": \"\",         \"finalize\": \"\",         \"libs\": [],         \"x\": 580,         \"y\": 160,         \"wires\": [             []         ]     } ]",
        "height": "10",
        "x": 870,
        "y": 980,
        "id": "53aba9752d327728",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "ui_update.flow",
                "v": "[     {         \"id\": \"442b5c2b006f3093\",         \"type\": \"tab\",         \"label\": \"Test flow\",         \"disabled\": false,         \"info\": \"\",         \"env\": []     },     {         \"id\": \"a4083f2cf9cbb97e\",         \"type\": \"inject\",         \"z\": \"442b5c2b006f3093\",         \"name\": \"\",         \"props\": [             {                 \"p\": \"payload\"             },             {                 \"p\": \"topic\",                 \"vt\": \"str\"             }         ],         \"repeat\": \"\",         \"crontab\": \"\",         \"once\": false,         \"onceDelay\": 0.1,         \"topic\": \"\",         \"payload\": \"\",         \"payloadType\": \"date\",         \"x\": 320,         \"y\": 160,         \"wires\": [             [                 \"9d436e020a6768f9\"             ]         ]     },     {         \"id\": \"9d436e020a6768f9\",         \"type\": \"function\",         \"z\": \"442b5c2b006f3093\",         \"name\": \"function 2\",         \"func\": \"\\nreturn msg;\",         \"outputs\": 1,         \"timeout\": 0,         \"noerr\": 0,         \"initialize\": \"\",         \"finalize\": \"\",         \"libs\": [],         \"x\": 580,         \"y\": 160,         \"wires\": [             []         ]     } ]",
                "vt": "json"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 480,
        "y": 980,
                "4215629d9434a8d0"
        "id": "f7474bf3bc523d1c",
        "type": "ui-group",
        "name": "FlowVIewer",
        "page": "d27c4567dd9e63ea",
        "width": "18",
        "height": 1,
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "d27c4567dd9e63ea",
        "type": "ui-page",
        "name": "Page New",
        "ui": "063c07e4a60e9f2f",
        "path": "/pageN",
        "icon": "home",
        "layout": "grid",
        "theme": "332c726ffc8c1d43",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "063c07e4a60e9f2f",
        "type": "ui-base",
        "name": "recon",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "titleBarStyle": "default",
        "notificationDisplayTime": 5
        "id": "332c726ffc8c1d43",
        "type": "ui-theme",
        "name": "VMTheme",
        "colors": {
            "surface": "#111111",
            "primary": "#cc1c82",
            "bgPage": "#111111",
            "groupBg": "#eeeeee",
            "groupOutline": "#555555"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "6px",
            "groupBorderRadius": "4px",
            "widgetGap": "6px"
