Dear Node-red community, I'm experiencing a problem with my dashboard, in case I use a table or svg nodes, all other flows are not displayed.
Thank you for your help.
Please stop node red and start it again from a command window and show us the startup log. Copy/paste please, not screen shot.
19 Dec 10:13:01 - [info] Node-RED version: v3.1.0
19 Dec 10:13:01 - [info] Node.js version: v20.9.0
19 Dec 10:13:01 - [info] Windows_NT 10.0.22621 x64 LE
19 Dec 10:13:02 - [info] Loading palette nodes
19 Dec 10:13:03 - [info] Dashboard version 1.0.2 started at /ui
19 Dec 10:13:03 - [warn] ------------------------------------------------------
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_base] 'ui_base' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_button] 'ui_button' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_dropdown] 'ui_dropdown' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_switch] 'ui_switch' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_slider] 'ui_slider' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_numeric] 'ui_numeric' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_text_input] 'ui_text_input' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_date_picker] 'ui_date_picker' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_colour_picker] 'ui_colour_picker' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_form] 'ui_form' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_text] 'ui_text' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_gauge] 'ui_gauge' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_chart] 'ui_chart' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_audio] 'ui_audio' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_toast] 'ui_toast' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_ui_control] 'ui_ui_control' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_template] 'ui_template' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_link] 'ui_link' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_tab] 'ui_tab' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_group] 'ui_group' already registered by module dashboard-evi
19 Dec 10:13:03 - [warn] [node-red-dashboard/ui_spacer] 'ui_spacer' already registered by module dashboard-evi
19 Dec 10:13:03 - [info] Settings file : C:\Users\mohtadi.kaabar\.node-red\settings.js
19 Dec 10:13:03 - [info] Context store : 'default' [module=memory]
19 Dec 10:13:04 - [info] User directory : \Users\xxxxxx\.node-red
19 Dec 10:13:04 - [warn] Projects disabled : editorTheme.projects.enabled=false
19 Dec 10:13:04 - [info] Flows file : \Users\xxxxxxx\.node-red\flows.json
19 Dec 10:13:04 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
19 Dec 10:13:04 - [info] Starting flows
19 Dec 10:13:04 - [info] Dashboard version 3.6.1 started at /ui
19 Dec 10:13:04 - [info] Started flows
You have two dashboards installed that are conflicting with each other... The main one is node-red-dashboard so I'd recommend removing the -evi one unless you have a need for it (in which case remove the main one)
You need to uninstall that.
Both are in use, how to uninstall without loosing any nodes configuration. Thank you
In a cmd window (terminal)
cd C:\Users\mohtadi.kaabar\.node-red
npm remove dashboard-evi
if node-red fails to start, start up in safe mode to fix up your flows...
node-red --safe
