I have node-red-dashboard 2.16.3 installed. It is recognizing current nodes. However when I try to open the UI I'm getting the " Welcome to the Node-RED Dashboard" splash screen.
[{"id":"224aabff.ed1b6c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"576c415.d45ffc","type":"mqtt in","z":"224aabff.ed1b6c","name":"","topic":"sensor/temperature_fahrenheit","qos":"2","broker":"8aa6812d.8ffab8","x":130,"y":460,"wires":[["7a161245.688e54","fff4dda3.08f788","b2b94400.8e9c3"]]},{"id":"9d0f3cd6.97496","type":"mqtt out","z":"224aabff.ed1b6c","name":"Fan","topic":"cmnd/DVES_56C3D0_fb/power","qos":"","retain":"","broker":"8aa6812d.8ffab8","x":1080,"y":360,"wires":[]},{"id":"6cf45f49.ae6108","type":"mqtt out","z":"224aabff.ed1b6c","name":"Light","topic":"cmnd/DVES_97FA91_fb/power","qos":"","retain":"","broker":"8aa6812d.8ffab8","x":330,"y":290,"wires":[]},{"id":"5bd447b3.6a7ae8","type":"timerswitch","z":"224aabff.ed1b6c","name":"Lights","ontopic":"","offtopic":"","onpayload":"1","offpayload":"0","disabled":false,"schedules":[{"on_h":"23","on_m":"00","on_s":"00","off_h":"17","off_m":"00","off_s":"00","valid":true}],"x":50,"y":290,"wires":[["b2839302.9d99"]]},{"id":"7a161245.688e54","type":"switch","z":"224aabff.ed1b6c","name":"Switch","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"90","vt":"num"},{"t":"btwn","v":"90","vt":"num","v2":"70","v2t":"num"},{"t":"lte","v":"70","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":350,"y":410,"wires":[["706a78f7.9bb4e8","cf570a78.734f58"],["9627ee8b.cf2e68","2882fa48.8e2e46"],["9627ee8b.cf2e68","dc87e59e.8188d8"]]},{"id":"cf570a78.734f58","type":"change","z":"224aabff.ed1b6c","name":"High","rules":[{"t":"set","p":"payload","pt":"msg","to":"***WARNING*** High Temp Alert - Temperature over 90 Degrees","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":420,"wires":[["759e9b6d.d323dc"]]},{"id":"759e9b6d.d323dc","type":"rbe","z":"224aabff.ed1b6c","name":"rbe","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":790,"y":460,"wires":[[]]},{"id":"2882fa48.8e2e46","type":"change","z":"224aabff.ed1b6c","name":"Normal","rules":[{"t":"set","p":"payload","pt":"msg","to":"Normal Temp Alert","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":460,"wires":[["759e9b6d.d323dc"]]},{"id":"dc87e59e.8188d8","type":"change","z":"224aabff.ed1b6c","name":"Low","rules":[{"t":"set","p":"payload","pt":"msg","to":"Low Temp Alert - Temperature Under 70 degrees","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":500,"wires":[["759e9b6d.d323dc"]]},{"id":"706a78f7.9bb4e8","type":"change","z":"224aabff.ed1b6c","name":"On","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":340,"wires":[["67376eb5.f6dca"]]},{"id":"9627ee8b.cf2e68","type":"change","z":"224aabff.ed1b6c","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":380,"wires":[["67376eb5.f6dca"]]},{"id":"67376eb5.f6dca","type":"rbe","z":"224aabff.ed1b6c","name":"rbe","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":790,"y":360,"wires":[["cf07059f.a4ddb"]]},{"id":"cf07059f.a4ddb","type":"ui_switch","z":"224aabff.ed1b6c","name":"","label":"Fan Switch","tooltip":"","group":"59d741dc.8dbb7","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","x":930,"y":360,"wires":[["9d0f3cd6.97496"]]},{"id":"b2839302.9d99","type":"ui_switch","z":"224aabff.ed1b6c","name":"","label":"Light Switch","tooltip":"","group":"59d741dc.8dbb7","order":4,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":190,"y":290,"wires":[["6cf45f49.ae6108"]]},{"id":"c11f22b5.ef3ea8","type":"ui_switch","z":"224aabff.ed1b6c","name":"","label":"Master Switch","tooltip":"","group":"59d741dc.8dbb7","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":80,"y":180,"wires":[["b2839302.9d99","cf07059f.a4ddb"]]},{"id":"37d91462.6efdcc","type":"mqtt in","z":"224aabff.ed1b6c","name":"","topic":"sensor/humidity","qos":"2","broker":"8aa6812d.8ffab8","x":80,"y":550,"wires":[["707fd33f.bd519c","64e71165.8a74d"]]},{"id":"fff4dda3.08f788","type":"ui_chart","z":"224aabff.ed1b6c","name":"","group":"12cfc3a1.1fd414","order":2,"width":12,"height":6,"label":"Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":370,"y":460,"wires":[[]]},{"id":"b2b94400.8e9c3","type":"ui_gauge","z":"224aabff.ed1b6c","name":"","group":"59d741dc.8dbb7","order":6,"width":0,"height":0,"gtype":"gage","title":"Temperature","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":370,"y":500,"wires":[]},{"id":"707fd33f.bd519c","type":"ui_chart","z":"224aabff.ed1b6c","name":"","group":"12cfc3a1.1fd414","order":1,"width":12,"height":6,"label":"Humidity","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":360,"y":550,"wires":[[]]},{"id":"64e71165.8a74d","type":"ui_gauge","z":"224aabff.ed1b6c","name":"","group":"59d741dc.8dbb7","order":5,"width":0,"height":0,"gtype":"gage","title":"Humidity","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":360,"y":590,"wires":[]},{"id":"8aa6812d.8ffab8","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.190","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"59d741dc.8dbb7","type":"ui_group","z":"","name":"Left Column","tab":"798a4ccd.4426b4","disp":false,"width":6,"collapse":false},{"id":"12cfc3a1.1fd414","type":"ui_group","z":"","name":"Right Column","tab":"798a4ccd.4426b4","order":2,"disp":true,"width":12,"collapse":false},{"id":"798a4ccd.4426b4","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":true,"hidden":false}]
