I just started with Node-RED and loaded node-red-dashboard be palette manage.
If I open the dashboard by http://IP-address:1880/ui I'm only getting a window with nothing
on it except the dashboard logo and wellcome. No icons, bars etc. whatsoever...
Have you added any ui nodes to a flow?
If you have added some widgets then open the Developer Console in the browser and see if it shows any errors when you refresh the screen.
What browser and version are you using?
Thanks for quick reply.
I'm unable to draw any widgets because there is nothing on the dashboard window to draw from.
I'm using the newest version of Firefox browser.
You don't add the widgets in the dashboard view, you add them in the normal editor view, where you build the rest of the flow.
Go to the editor http://your_RPI_IP_address:1880 then in the LEFT sidebar scroll to the bottom where you will find the ui nodes. add one to your flow and do a deploy. Then open the dashboard and see if it shows up.
Or you could import this flow:
[{"id":"1cdfd83af2d9da49","type":"inject","z":"1ca45eabffa21dfd","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"Hello World","payloadType":"str","x":230,"y":540,"wires":[["c8315e5c1d48feb3"]]},{"id":"c8315e5c1d48feb3","type":"ui_text","z":"1ca45eabffa21dfd","group":"fce60e45af73a149","order":0,"width":0,"height":0,"name":"","label":"text","format":"{{msg.payload}}","layout":"row-spread","className":"","style":false,"font":"","fontSize":16,"color":"#000000","x":430,"y":540,"wires":[]},{"id":"fce60e45af73a149","type":"ui_group","name":"Default","tab":"031b621cdb91dec1","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"031b621cdb91dec1","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
and deploy and check the dashboard
Is this tutorial online? Can you show us the URL?
It's Random Nerd Tutorials
There are a lot of YouTube video tutorials on Node-red dashboard which might be easier to follow if you are not doing well with an English text based one.
The order of doing things in that tutorial is a bit odd. Did you manage to import the flow that @zenofmud posted. If you don't know how to do that (or even if you do know how to do it) then I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
..well, thanks again for your comments:
I'm following an e-book by Random Nerd Tutorial "SMART HOME with Raspberry Pi, ESP32, and ESP8266 eBook" so I can't send any links.
And @GogoVega:That's exactly the tutorial I'm following.
Although my native language is German I'm very used to English und I'd rather downloaded the english
version than the german for my Node-RED projects.
Colin's advise to add an UI node (gauge) to the normal editor view didn't work, in the dasdboard window/view I still get "Please add some UI nodes to your flow and redeploy".
Same after import of zenofmud's flow.
Import of @flowfuse/node-red-dashboard was unsuccessfull, got an error..
Next I will try Node-RED Essentials as recommended by Colin.
Please run, in a command window
node-red-stop
node-red-start
and copy/paste the output here. Copy/paste not screenshot please.
pi@raspberrypiZeroX:~ $ node-red-stop
Stop Node-RED
Use node-red-start to start Node-RED again
pi@raspberrypiZeroX:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.102:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
12 Jan 11:13:45 - [info]
Welcome to Node-RED
12 Jan 11:13:45 - [info] Node-RED version: v3.1.3
12 Jan 11:13:45 - [info] Node.js version: v18.19.0
12 Jan 11:13:45 - [info] Linux 6.1.21-v8+ arm64 LE
12 Jan 11:13:47 - [info] Loading palette nodes
12 Jan 11:13:50 - [info] Dashboard version 3.6.2 started at /ui
12 Jan 11:13:52 - [info] Settings file : /home/pi/.node-red/settings.js
12 Jan 11:13:52 - [info] Context store : 'default' [module=memory]
12 Jan 11:13:52 - [info] User directory : /home/pi/.node-red
12 Jan 11:13:52 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 Jan 11:13:52 - [info] Flows file : /home/pi/.node-red/flows.json
12 Jan 11:13:52 - [warn] Encrypted credentials not found
12 Jan 11:13:52 - [info] Server now running at http://127.0.0.1:1880/
12 Jan 11:13:52 - [info] Starting flows
12 Jan 11:13:52 - [info] Started flows
sorry for the layout, but this was the only way to get it through. Got first: New users are allowed onlx 2 links
in a post..
When you search for http://127.0.0.1:1880/ui does the search change and became http://127.0.0.1:1880/ui/#!/0?socketid=something ?
no, no change.
and there is another issue:
I'm unable to delete a Flow (3) on the regular Node-RED interface. In all attempts the
delete button is inactive.
You know you can't delete the flow if it's the only one
The runtime log shows no errors and what does the browser console say (for editor and dashboard) ?
That is the recommended way to post logs.
From the /ui page, open the Developer Tools Console in your browser and refresh the page. Do you see any errors in the console?
What browser are you using? Can you try another browser?
