Dashboard is not working anymore
Hi community,
First of all: sorry for my english…
i got a Problem with my Dashboard, after i finished programming some Nodes and adding their data to the Dashboard, i shut my raspberry down.
After i reboot it this morning again and wanted to check my Dashboard, it doesn t worked any longer.
There is always this message:
Welcome to the Node-RED Dashboard
Please add some UI nodes to your flow and redeploy.
but i already added some ui Dashboard notes…
could any one help my to fix this Problem?
It would be useful to see the log that Node-RED prints when you start it.
Also have you installed any other nodes that include the word “dashboard”? If you have these unfortunately stop the node-red-dashboard from working. You should delete them and then restart Node-RED
here is what node red prints:
Node-Red start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.44:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
14 Jun 10:42:53 - [info]
Welcome to Node-RED
14 Jun 10:42:53 - [info] Node-RED version: v0.18.6
14 Jun 10:42:53 - [info] Node.js version: v8.11.2
14 Jun 10:42:53 - [info] Linux 4.14.34-v7+ arm LE
14 Jun 10:42:54 - [info] Loading palette nodes
14 Jun 10:42:59 - [info] Dashboard version 2.9.4 started at /ui
14 Jun 10:43:00 - [warn] ------------------------------------------------------
14 Jun 10:43:00 - [warn] [node-red-bluemix-nodes/tcp] ‘tcp request’ already registered by module node-red
14 Jun 10:43:00 - [warn] [node-red-bluemix-nodes/udp] ‘udp out’ already registered by module node-red
14 Jun 10:43:00 - [info] Settings file : /home/pi/.node-red/settings.js
14 Jun 10:43:00 - [info] User directory : /home/pi/.node-red
14 Jun 10:43:00 - [warn] Projects disabled : editorTheme.projects.enabled=false
14 Jun 10:43:00 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
14 Jun 10:43:00 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
You should set your own key using the ‘credentialSecret’ option in
14 Jun 10:43:01 - [info] Starting flows
TypeError: Cannot read property ‘id’ of undefined
at createSubflow (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/Flow.js:362:61)
at Flow.start (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/Flow.js:97:41)
at start (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/index.js:327:29)
at tryCatchReject (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:804:4)
at Fulfilled.when (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:592:4)
at Pending.run (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:62:19)
at Scheduler.drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:27:9)
at _combinedTickCallback (internal/process/next_tick.js:131:7)
at process._tickCallback (internal/process/next_tick.js:180:9)
14 Jun 10:43:02 - [info] Started flows
14 Jun 10:43:03 - [info] [sqlitedb:6573ca80.1e0d34] opened /tmp/sqlite ok
14 Jun 10:43:36 - [info] Stopping flows
14 Jun 10:43:36 - [info] Stopped flows
14 Jun 10:43:36 - [info] Starting flows
at /usr/lib/node_modules/node-red/red/runtime/nodes/flows/index.js:164:21
14 Jun 10:43:38 - [info] Started flows
i don t have any other nodes including the word Dashboard…
Do you need the following nodes that you have installed?
They are for use in Bluemix but you have it installed on a raspberry pi. Try deleting them and restarting node-red.
i already tried to delet them but node red says they are in use, what they defenetly aren t…
Unbenannt
So that suggests you are using the mongoldb nodes. If you are definitely not…
In a terminal
node-red-stop
cd ~/.node-red
and then
npm uninstall node-red-bluemix-nodes
okay now the terminal says:
Unbenannt
but i defenitly had no node in my flow which is called mongoDB
If you look at the menubar in Node-RED there is a “Search flows” option and see if you can find it
Otherwise look at “Configuration nodes”
yes thank u i fix it now :slight_smile:
Which one was it? A node or a configuration node?
probably it was a configuration node which blocked my Dashboard ui. So i deleted all background nodes and stuff i don’t needed any more and now it works.
I hope it is still working tomorrow
