Mrous
4 October 2021 15:47
1
I made a bar chart with this data. And I would like to have the value CUMULWATT with only 2 decimals.
Here is my code, but it doesn't work ..
Edit Function Node
var m = {};
m.labels = ;
m.data = ;
m.series = ["Euros"];
var arrayLength = msg.payload.length;
for (var i = 0; i < arrayLength; i++) {
m.labels.push((msg.payload[i].fecha3));
m.data.push(msg.payload[i].CUMULWATT*0.00018).toFixed(2);
return {payload:[m],topic:msg.topic};
Thank you
I understand that value.toFixed(2) will give you a string. As you want to get a number probably you have to convert the result to float again. Something like
parseFloat(value.toFixed(2)). I can´t test right now though.
E1cid
4 October 2021 16:15
3
You would be converting the length of the array you just pushed to. As push will return the array length.
The toFixed needs to be inside the push ( ). Would probably be better to use Math.round()
