Beebotte. Nothing showing on channel or dashboard
@Richard238 Do you need to display the information n the BeeBotte dashboard? NR has it's own dashboard.
If you do need to display it on the BeeBtte dashboard you should see if you can get some help from them.
+1 for using the Node-red dashboard, which you are already familiar with.
You might consider a local database rather than the smallish number of retained data at Beebotte.
A lot of people favour Influxdb. I use Mariadb (= MySQL).
And why are you using a cloud based MQTT broker anyway - is the source of the data outside of your own LAN?
Beebotte's support seems limited, I've emailed them, not holding out much hope.
No, it was there so I thought I'd try and use it. How hard can it be??!!
Well after playing with it, all I can reply to your statement is "hahahahahahahaha!!!" (big grin)
I have sensors feeding a MySQL db, in turn feeding Grafana.
My Greenhouse
Some Pi stats
Garage door height. the sensor is OK, but sadly the Pi died :frowning:
MQTT seems popular so I thought, let's give that a go, using a cloud broker to save some Pi overhead.
I think I'll stick with MySQL & Grafana
Mosquitto is very lightweight. Unless you are trying to send many hundreds of MQTT messages/second you will not notice the additional resources. So unless you need to use a cloud MQTT broker in order to get access from multiple systems across the internet then don't bother.
Bother I won't!. Off to swot up on Mosquitto
I Tested Beebotte mqtt and found that data should be in format as given in their documentation.
  • In order to persist a message sent using MQTT, the message payload MUST respect the following JSON format: {"data": object, "write": true}.
  • As stated in the MQTT - Beebotte Bridge section earlier, MQTT messages are private by default. In order to publish a public message the message payload MUST respect the following format: {"data": object, "ispublic": true}
Please refer the documentation on below link:-
https://beebotte.com/docs/mqtt#bridge
Regards,
Prasoon Tewari
