Before re-deploy i want to clear global variable content how to do that ?
You can delete it manually in the Context side-bar or by using an Inject and Change node.
However, there are no runtime events available to trigger a flow automatically.
Make sure that you do a full deploy, that clears all in-memory variables I think.
I believe you can also use JS in a function node:
global.set('variableName',undefined);
