Hello, i'm just starting on nodered and I have a problem. I'm creating a custom node but can't get the js file to work. In my html file i have this :
<div class="form-row">
<input type="text" id="node-input-finalMsg" name="Message Final"/>
</div>
And in my js file :
module.exports = function (RED) {
function AffichageNode(config) {
RED.nodes.createNode(this, config);
var node = this;
this.finalMsg = config.finalMsg;
this.on('input', function () {
console.log(node.finalMsg)
RED.nodes.registerType("Affichage", AffichageNode);
But if i run this code I get an "undefined" in the console. can someone help?
Is that your entire html file?
Its missing the <script> parts ( see https://nodered.org/docs/creating-nodes/node-html)
As you want to take something from the configuration part you should also look at the "Configuration Nodes" page. https://nodered.org/docs/creating-nodes/config-nodes
this is a sample, not the entire html, here my html file complete
//stuff
RED.nodes.registerType('Affichage', {
category: 'Gertrude',
color: '#91db85',
defaults: {
name: { value: "" }
inputs: 1,
outputs: 1,
icon: "affichage.png",
label: function () {
return this.name || "Affichage";
oneditprepare: function() {
//stuff
oneditcancel: function(){
//stuff
oneditsave: function(){
//stuff
</script>
<script type="text/x-red" data-template-name="Affichage">
//html here
</div>
</script>
<script type="text/x-red" data-help-name="Affichage">
</script>
You need to include finalMsg in the defaults object so the editor knows this is a property to save to the node configuration.
color: '#91db85',
defaults: {
finalMsg: { value: ""},
name: { value: "" }
inputs: 1,
outputs: 1,
This is what I did and I still get the undefined
