Try this...
ENERGY total should appear in msg.payload in the next part of your flow.
Oops - just re-read your original post - I doubt if the above is wwhat you want (sorry).
Try this...
Thank you Dave,
but I think your approach is essentially what I initially did and which does produce the correct output IF that key exists.
I am trying to prevent errors by first checking if the key exists and only then creating the new msg.
Umm - this is what I would have tried (just like your attempt).
Not near a PC so can't try the code at the moment
if ('Total' in msg.payload.ENERGY) {
console.log('Total exists in msg.payload.ENERGY');
} else {
console.log('Total does not exist in msg.payload.ENERGY');
Sorry - this was meant for you not me.
Unfortunately same as with my approach in first post.
TypeError: Cannot use 'in' operator to search for 'Total' in undefined
Okay, I got a step closer.
I cannot check for the key directly but first need to ensure that the object is actually present.
if (msg.payload.ENERGY !== undefined) {
var msg = { payload: msg.payload.ENERGY['Power'] };
EDIT:
And in a second step then check the key.
This seems to work:
if (msg.payload.ENERGY['Power'] !== undefined) {
Now I need to figure out the wildcard problem.
For the record, you don't need to use ['Power']
. You only need to do that if the property name (Power) has special characters in it. So you can use msg.payload.ENERGY.Power
I am using the Total in a second step to ensure that I do not get an error if the object ENERGY exists but does not have a key named Total.
Or do you mean that this is redundant because the error is only linked to missing object and not to missing keys?
Sorry, I had multiple typos in my post, now corrected. I just meant that wherever you use ['Power']
you can use .Power
For the wildcard problem I think I need to use regular expressions, but I seem to be doing it wrong.
if (msg.payload./ATC/ !== undefined) {
var msg = { payload: msg.payload./ATC/ };
This should be all payloads that contain an object starting with "ATC", but I get a syntax error.
Does the payload contain multiple properties or will it only ever contain one, such as ATC123?
Also is the ATC always at the start?
The payload can contain all kinds of properties (if I am using the word 'properties' correctly).
Placement could theoretically vary but it is usually not at the start.
Here is an example payload:
{"Time":"2023-09-03T14:48:50","ATC0d5c0c":{"mac":"a4c1380d5c0c","Temperature":21.6,"Humidity":66.2,"DewPoint":15,"Btn":0,"Battery":37,"RSSI":-68},"ATC8f1b4f":{"mac":"a4c1388f1b4f","Temperature":21.9,"Humidity":62.9,"DewPoint":14.5,"Btn":0,"Battery":69,"RSSI":-62},"TempUnit":"C"}
Here is a function which detects if msg.payload has an element whose key begins with "ATC".
I don't know how efficient it is!
for (let key in msg.payload) {
node.warn (key)
if (/^ATC/.test(key)) {
node.warn (key + " begins with ATC")
node.warn ("It's value is " + msg.payload[key])
In that case you need to test all the properties (or keys) to see if any of them match.
I didn't mean if it is the first property, I meant if then name starts with ATC, or if the ATC could be anywhere in the property name.
Assuming that it is always at the start then you can iterate through the properties (or keys) using something like
Object.keys(msg.payload).forEach((element) => {
if (element.startsWith("ATC")) {
msg.payload = msg.payload[element]
node.send(msg)
Your code works, thank you!
But I am a bit surprised that I have to test all keys one by one/looping through each. Why is that?
When I use
this also checks if any of the keys matches 'Power'. Would the same approach not be possible by ending the msg.payload.ENERGY
with a regular expression for "starts with ATC"?
msg.payload.ENERGY + regular expression for "starts with ATC"
EDIT1:
So, this did not work
if (msg.payload.startsWith("ATC") !== undefined) {
var msg = { payload: msg.payload.startsWith("ATC") };
TypeError: msg.payload.startsWith is not a function
Firstly, you mixed dot with bracket notation. Secondly, you cannot use wildcards in object or array selectors.
What you can do is to use a filter
. Please do some reading on the filter function in JavaScript.
Array.prototype.filter() - JavaScript | MDN (mozilla.org)
Also note that filter
is an Array function. If your payload is an object rather than an array, you will need to convert using Object.keys
. That gets you an array of the keys that you can filter and pass into a loop. Alternatively, if the key is also represented in the objects values, you can use Object.values
and filter more directly.
Follow up question.
The output of this is e.g.
{"mac":"a4c1380d5c0c","Temperature":21.6,"Humidity":64.7,"DewPoint":14.7,"Btn":0,"Battery":37,"RSSI":-64}
but there is also a payload undefined
So the filtering is not quite working correctly yet.
MQTT node is set to output parsed JSON object. So it is always a parsed JSON object that is being processed.
I was unsuccessful with the filter function also.
var msg = { payload: msg.payload.filter(function (str) { return str.includes('ATC'); }) };
Gives me error
TypeError: msg.payload.filter is not a function
But msg.payload is my array, is it not?
Show us the full function please.
It is worth finding why it does not work, but @TotallyInformation is correct, using filter would probably be better.
It doesn't check if any of the keys match, it just goes to the one called Power and tries to get it. Only then does it realise that it does not exist.
It is like the difference between phoning extension 123 and seeing if anyone replies, rather than asking if any of the 12x numbers reply. In the first case (extension 123 or key Power) you just try it, for the second (12x or ATX???) the only way to know is to try them all.
Tried filter() approach in the message above yours. Not successful yet
Regarding the if expression: Thank you for the clear explanation. Maybe that is why it is so fast. It jumps directly and then fails rather than iterating through the array.
