Beginner: String(INT) global variable convert to number?
Hi!
First time trying Node-Red with the Weidmuller program.
I have a temperature sensor and I'm trying to get this to convert to $number but I don't understand at all how to go further. Checked forums, youtube etc.
My variable is currently a "Int" (string). I'm new with JavaScript aswell. Have MQTT Explorer connected.
Any good and easy explanation for a beginner?
gragr
Hi @r4sby, welcome to the forum.
At the right hand side of ther debug window are a couple of buttons "Copy path" and "Copy value"
If you click Copy path on the line containing your value [and paste it somewhere] you see that the value is at msg.payload.MEASURED_TEMP.value.
I'm not sure what your change node Jsonata expression is trying to do but it needs to work with the path just shown. This seems to work:
You could also convert it using a function node. This would be my approach because I dislike Jsonata syntax.
msg.payload = Number(msg.payload.MEASURED_TEMP.value);
Thank you for a quick reply and good information.
I found out that my variable had 2 outputs, first is "Array of process data",
Other output "Map of process data". First I used Map of process data, by misstake and figured it out :grinning:
I also did what you posted. Worked! :smile:
