Note - the status only reflects what MQTT sees. Depending on where the network connection breaks it may need the MQTT keepalive to fail in order to detect the breakage - which by default we set to 60 seconds. Any messages sent in that period will be handled by MQTT a) if using QoS2 to send them and clean-session is set to false.and b) you don't lose power at the client end (as we do not persist them to "disk"). Once the disconnect has been detected then any other messages to be sent will be dropped - so an alternative queue (possibly triggered by the status/status node) can be created.
A simple example would be like this
[{"id":"f9ec7a29.852b18","type":"inject","z":"82738787.0e0338","name":"","topic":"test","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":600,"wires":[["8e6485b.fc3ce78"]]},{"id":"d25c0e58.e75d7","type":"mqtt out","z":"82738787.0e0338","name":"","topic":"","qos":"2","retain":"","broker":"5085b198.064c4","x":630,"y":600,"wires":[]},{"id":"ccb84c90.3f15e","type":"debug","z":"82738787.0e0338","name":"","active":false,"console":"false","complete":"false","x":650,"y":660,"wires":[]},{"id":"8e6485b.fc3ce78","type":"function","z":"82738787.0e0338","name":"Status gated queue","func":"\nvar MAX_DEPTH = 10;\n\n// if queue doesn't exist, create it\ncontext.queue = context.queue || [];\ncontext.pass = context.pass || false;\n\n// Use MQTT connected status to gate flow\nif (msg.hasOwnProperty(\"status\")) {\n    if (msg.status.text.indexOf(\".connected\") !== -1) { \n        setTimeout(function() { \n            while (context.queue.length > 0) {\n                var m = context.queue.shift();\n                node.send(m); \n            }\n            context.pass = true; \n            node.status({});\n        },5);\n    }\n    else { context.pass = false; }\n}\nelse {\n    if (context.pass) { return msg; }\n    else { \n        context.queue.push(msg); \n        if (context.queue.length > MAX_DEPTH) { context.queue.shift(); }\n        node.status({text:context.queue.length});\n    }\n}\nreturn null;","outputs":1,"noerr":0,"x":430,"y":600,"wires":[["ccb84c90.3f15e","d25c0e58.e75d7"]]},{"id":"147525f9.9ff5ba","type":"status","z":"82738787.0e0338","name":"","scope":["d25c0e58.e75d7"],"x":220,"y":660,"wires":[["8e6485b.fc3ce78"]]},{"id":"5085b198.064c4","type":"mqtt-broker","z":"","name":"","broker":"myremotebroker","port":"1883","clientid":"test","usetls":false,"compatmode":true,"keepalive":"20","cleansession":false,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
This has a maximum queue depth of 10 (just for demo) and again only persists in memory.
