Best way to configure my node via messages
My idea was just to keep the user experiences consistent across the dashboard widgets usage. But even if property cant be used the main concept still stays valid.
as I said - it "should" be ok - but if (as per your example) there happened to be a property called userdefined_led_name_1 in the nodes ui then you would be overwriting that... (and that may indeed be what you want...) - but just noting that ui_control may already be handled.
Testing scope grows exponentially by a factor of created configuration options count :wink:
