Big CSV: read latest line
Hi!
this is my first post, so let me introduce myself. My name is Jay and I am from Switzerland.
I have a tab delimited CSV file from a door controller which is growing fast
Could you help me, how to extract the last line?
Best regards,
Jay
Tail node connected to a csv node should do the job nicely (assuming the file gets closed between each line being written)
If your system is Linux based, take a look at the tail node. I believe the tail node, based on Linux taif -f command works if the file is not closed after every write, typically used to monitor the output of log files.
You may need to modify your writing process to call flush() after every line is written if you want timely updates.
