BIGSSH not recognising external input correctly
Hi Node-RED community.
I have an issue where the BIGSSH node will not accurately relay a command payload )from an external node) when a pipe ("|") is used to process the output of the initial command.
Example: "whois xxx.xxx.xxx.xxx | grep netname"
IF I enter the command into the BIGSSH node directly it outputs correctly, however if passed to the node as an argument, it fails. I particularly need to input this from outside BIGSSH due to the IP address not being static.
Has anyone had experience with this?
Thanks in advance.
You might want to contact the author on GitHub. I'd also mention to the author that e hasn't provided any example flow.
Thanks for your help. The Dev released a new version to enable the capability! Also added some example flows. Cheers.
