Bug in JSONata inputs or just me?
I think this JSONata input should be outlined in red and should make the node invalid. Because the properties are not enclosed in double-quotes as they should be for valid JSON.
Am I right or not?
It is not an invalid JSONata expression.
Given what you have written, it will use the value of msg.random as the key name in the object.
Ah, OK. Well actually, it returns nothing I'm afraid.
No problem, so just me then. :smiley:
If you don’t have msg.random set, then nothing will get set :wink:
