Bug position needle widget gauge
hello,
II am reporting a fairly recurring random bug in the needle position of the gauge D2 widget following whether the pages panel is open or closed.
Have a good day
What version of @flowfuse/node-red-dashboard are you using (check in Manage palette)?
Your problem looks like issue #587 but that was fixed months ago I think.
my version is 1.14.0
Can you create a simple example flow showing the problem please? Just inject nodes and chart widgets,export those nodes and post them here.
In order to make your flow readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
hello,
below code and screenshot. :grinning:
        "id": "6933b544bed30218",
        "type": "tab",
        "label": "Flux 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "ad9215333a9202f3",
        "type": "ui-gauge",
        "z": "6933b544bed30218",
        "name": "batterie",
        "group": "6d8e8961b6e55d4b",
        "order": 1,
        "width": "4",
        "height": "3",
        "gtype": "gauge-34",
        "gstyle": "rounded",
        "title": "Pile",
        "units": "Volts",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#ea5353"
                "from": "3.4",
                "color": "#ffc800"
                "from": "3.6",
                "color": "#5cd65c"
        "min": 0,
        "max": "5",
        "sizeThickness": "10",
        "sizeGap": 4,
        "sizeKeyThickness": 8,
        "styleRounded": true,
        "styleGlow": false,
        "className": "",
        "x": 460,
        "y": 160,
        "id": "a58f9c6c3651cade",
        "type": "ui-gauge",
        "name": "temperature",
        "order": 2,
        "width": "4",
        "height": "3",
        "title": "Température",
        "units": "°C",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "30",
                "color": "#ffc800"
                "from": "50",
                "color": "#ea5353"
        "min": 0,
        "max": "100",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 470,
        "y": 200,
        "id": "242a8ebd0ea3b43b",
        "type": "ui-gauge",
        "order": 6,
        "width": "4",
        "height": "3",
        "gstyle": "needle",
        "title": "Axe X",
        "units": "",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "4",
                "color": "#ffc800"
                "from": "7",
                "color": "#ea5353"
        "min": 0,
        "max": "10",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 450,
        "y": 240,
        "id": "15e463c0bb57c38d",
        "type": "ui-gauge",
        "order": 5,
        "width": "4",
        "height": "3",
        "gstyle": "needle",
        "title": "Axe Y",
        "units": "",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "4",
                "color": "#ffc800"
                "from": "7",
                "color": "#ea5353"
        "min": 0,
        "max": "10",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 450,
        "y": 280,
        "id": "a2aadbec1346f6dd",
        "type": "ui-gauge",
        "order": 4,
        "width": "4",
        "height": "3",
        "gstyle": "needle",
        "title": "Axe Z",
        "units": "",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "4",
                "color": "#ffc800"
                "from": "7",
                "color": "#ea5353"
        "min": 0,
        "max": "10",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 450,
        "y": 320,
        "id": "8d1c4951a1e8612f",
        "type": "ui-gauge",
        "order": 3,
        "width": "4",
        "height": "3",
        "gstyle": "needle",
        "title": "Score",
        "units": "",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "10",
                "color": "#ffc800"
                "from": "30",
                "color": "#ea5353"
        "min": 0,
        "max": "100",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 450,
        "y": 360,
        "id": "2ec38e6f11cdb358",
        "type": "function",
        "name": "function 2",
        "func": "msg.payload=(Math.floor(Math.random()*10));\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 500,
                "240c7bc81d267b3e"
        "id": "240c7bc81d267b3e",
        "type": "debug",
        "name": "debug 17",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 660,
        "y": 520,
        "id": "de85e8af44f2ce7f",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "10",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 130,
        "y": 520,
                "2ec38e6f11cdb358"
        "id": "6d8e8961b6e55d4b",
        "type": "ui-group",
        "name": "My Group",
        "page": "708dfb360d3a65f0",
        "width": "25",
        "height": "1",
        "order": 1,
        "showTitle": false,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "708dfb360d3a65f0",
        "type": "ui-page",
        "name": "test",
        "ui": "f74c07c1792e9715",
        "path": "/page5",
        "icon": "home",
        "layout": "grid",
        "theme": "02ab8c906f24d414",
        "order": 5,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "f74c07c1792e9715",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "showPageTitle": true,
        "navigationStyle": "default",
        "titleBarStyle": "default"
        "id": "02ab8c906f24d414",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "pagePadding": "5px",
            "groupGap": "5px",
            "groupBorderRadius": "4px",
            "widgetGap": "5px"
I think you are missing something in your flow as nothing is connected to the inputs. However I am able to see the symptom you describe. Interestingly, it is ok on initially going to the page, but if the screen is refreshed then the problem is seen when the menu drops down.
I did not look carefully enough at the issue I posted to, as it links to another, issue #560, which is still open. I suggest you add a comment to that issue pointing out that it is affecting you, and linking to this post for reference.
sorry, I don't have a github account and I don't know how it works. I will let the professionals read my problem and bring it up on this platform.
It is worth doing that so you are not reliant on others using their time. I will post a comment there.
