joha91
13 November 2020 13:22
1
Hey all,
I wanted to start working with the project setting, but I allways get this error message:
Normally I run Node-Red in my ioBroker, but I also did a test in a fresh installed node-red instance now --> same error.
I´m running on a Rasp 3 model B
Thanks a lot and wish you a nice weekend
Regards
What does the NR log say?
joha91
13 November 2020 19:49
3
I think nothing special.
It somehow tries to reconnect which is not possible, but I dont know if it comes from that error.
Sorry for the million useless logs
13 Nov 20:22:18 - [warn] [function:::LOG::] 14.03
13 Nov 20:22:18 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:22:18 - [warn] [function:::LOG::] true
2020-11-13 20:22:20.146 - warn: node-red.0 (17987) 13 Nov 20:22:20 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:22:20.147 - warn: node-red.0 (17987) 13 Nov 20:22:20 - [warn] [function:::LOG::] Payload
13 Nov 20:22:20 - [warn] [function:::LOG::] 166.94
13 Nov 20:22:20 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:22:20 - [warn] [function:::LOG::] true
2020-11-13 20:22:30.226 - warn: node-red.0 (17987) 13 Nov 20:22:30 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:22:30.227 - warn: node-red.0 (17987) 13 Nov 20:22:30 - [warn] [function:::LOG::] Payload
13 Nov 20:22:30 - [warn] [function:::LOG::] 124.22
13 Nov 20:22:30 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:22:30 - [warn] [function:::LOG::] true
2020-11-13 20:22:41.521 - warn: node-red.0 (17987) 13 Nov 20:22:41 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:22:41.523 - warn: node-red.0 (17987) 13 Nov 20:22:41 - [warn] [function:::LOG::] Payload
13 Nov 20:22:41 - [warn] [function:::LOG::] 211.13
13 Nov 20:22:41 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:22:41 - [warn] [function:::LOG::] true
2020-11-13 20:22:51.609 - warn: node-red.0 (17987) 13 Nov 20:22:51 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:22:51.611 - warn: node-red.0 (17987) 13 Nov 20:22:51 - [warn] [function:::LOG::] Payload
13 Nov 20:22:51 - [warn] [function:::LOG::] 167.43
13 Nov 20:22:51 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:22:51 - [warn] [function:::LOG::] true
2020-11-13 20:23:01.703 - warn: node-red.0 (17987) 13 Nov 20:23:01 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:23:01.705 - warn: node-red.0 (17987) 13 Nov 20:23:01 - [warn] [function:::LOG::] Payload
13 Nov 20:23:01 - [warn] [function:::LOG::] 73.16
13 Nov 20:23:01 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:23:01 - [warn] [function:::LOG::] true
2020-11-13 20:23:11.806 - warn: node-red.0 (17987) 13 Nov 20:23:11 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:23:11.808 - warn: node-red.0 (17987) 13 Nov 20:23:11 - [warn] [function:::LOG::] Payload
2020-11-13 20:23:11.810 - warn: node-red.0 (17987) 13 Nov 20:23:11 - [warn] [function:::LOG::] 138.95
13 Nov 20:23:11 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:23:11 - [warn] [function:::LOG::] true
2020-11-13 20:23:20.483 - warn: node-red.0 (17987) [warn] 2020-11-13 19:23:20.483 connection timed out, retrying...
2020-11-13 20:23:23.485 - warn: node-red.0 (17987) [warn] 2020-11-13 19:23:23.485 connection timed out, retrying...
2020-11-13 20:23:31.925 - warn: node-red.0 (17987) 13 Nov 20:23:31 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:23:31.927 - warn: node-red.0 (17987) 13 Nov 20:23:31 - [warn] [function:::LOG::] Payload
13 Nov 20:23:31 - [warn] [function:::LOG::] 129.62
13 Nov 20:23:31 - [warn] [function:::LOG::] waschmachineLäuft variable
2020-11-13 20:23:31.933 - warn: node-red.0 (17987) 13 Nov 20:23:31 - [warn] [function:::LOG::] true
2020-11-13 20:23:42.005 - warn: node-red.0 (17987) 13 Nov 20:23:42 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:23:42.007 - warn: node-red.0 (17987) 13 Nov 20:23:42 - [warn] [function:::LOG::] Payload
13 Nov 20:23:42 - [warn] [function:::LOG::] 235.68
13 Nov 20:23:42 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:23:42 - [warn] [function:::LOG::] true
2020-11-13 20:23:54.003 - warn: node-red.0 (17987) 13 Nov 20:23:54 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:23:54.005 - warn: node-red.0 (17987) 13 Nov 20:23:54 - [warn] [function:::LOG::] Payload
13 Nov 20:23:54 - [warn] [function:::LOG::] 294.6
13 Nov 20:23:54 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:23:54 - [warn] [function:::LOG::] true
2020-11-13 20:24:04.091 - warn: node-red.0 (17987) 13 Nov 20:24:04 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:24:04.093 - warn: node-red.0 (17987) 13 Nov 20:24:04 - [warn] [function:::LOG::] Payload
13 Nov 20:24:04 - [warn] [function:::LOG::] 236.66
13 Nov 20:24:04 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:24:04 - [warn] [function:::LOG::] true
2020-11-13 20:24:15.376 - warn: node-red.0 (17987) 13 Nov 20:24:15 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:24:15.379 - warn: node-red.0 (17987) 13 Nov 20:24:15 - [warn] [function:::LOG::] Payload
13 Nov 20:24:15 - [warn] [function:::LOG::] 319.15
13 Nov 20:24:15 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:24:15 - [warn] [function:::LOG::] true
2020-11-13 20:24:25.457 - warn: node-red.0 (17987) 13 Nov 20:24:25 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:24:25.460 - warn: node-red.0 (17987) 13 Nov 20:24:25 - [warn] [function:::LOG::] Payload
13 Nov 20:24:25 - [warn] [function:::LOG::] 241.08
13 Nov 20:24:25 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:24:25 - [warn] [function:::LOG::] true
2020-11-13 20:24:35.547 - warn: node-red.0 (17987) 13 Nov 20:24:35 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:24:35.549 - warn: node-red.0 (17987) 13 Nov 20:24:35 - [warn] [function:::LOG::] Payload
13 Nov 20:24:35 - [warn] [function:::LOG::] 97.22
13 Nov 20:24:35 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:24:35 - [warn] [function:::LOG::] true
2020-11-13 20:24:45.624 - warn: node-red.0 (17987) 13 Nov 20:24:45 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:24:45.626 - warn: node-red.0 (17987) 13 Nov 20:24:45 - [warn] [function:::LOG::] Payload
13 Nov 20:24:45 - [warn] [function:::LOG::] 144.85
13 Nov 20:24:45 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:24:45 - [warn] [function:::LOG::] true
2020-11-13 20:25:05.855 - warn: node-red.0 (17987) 13 Nov 20:25:05 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:25:05.857 - warn: node-red.0 (17987) 13 Nov 20:25:05 - [warn] [function:::LOG::] Payload
13 Nov 20:25:05 - [warn] [function:::LOG::] 120.79
13 Nov 20:25:05 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:05 - [warn] [function:::LOG::] true
2020-11-13 20:25:15.882 - warn: node-red.0 (17987) 13 Nov 20:25:15 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:25:15.887 - warn: node-red.0 (17987) 13 Nov 20:25:15 - [warn] [function:::LOG::] Payload
13 Nov 20:25:15 - [warn] [function:::LOG::] 237.15
13 Nov 20:25:15 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:15 - [warn] [function:::LOG::] true
2020-11-13 20:25:28.070 - warn: node-red.0 (17987) 13 Nov 20:25:28 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:25:28 - [warn] [function:::LOG::] Payload
13 Nov 20:25:28 - [warn] [function:::LOG::] 328.97
13 Nov 20:25:28 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:28 - [warn] [function:::LOG::] true
2020-11-13 20:25:38.165 - warn: node-red.0 (17987) 13 Nov 20:25:38 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:25:38 - [warn] [function:::LOG::] Payload
13 Nov 20:25:38 - [warn] [function:::LOG::] 251.39
13 Nov 20:25:38 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:38 - [warn] [function:::LOG::] true
2020-11-13 20:25:48.230 - warn: node-red.0 (17987) 13 Nov 20:25:48 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:25:48.237 - warn: node-red.0 (17987) 13 Nov 20:25:48 - [warn] [function:::LOG::] Payload
13 Nov 20:25:48 - [warn] [function:::LOG::] 48.61
13 Nov 20:25:48 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:48 - [warn] [function:::LOG::] true
2020-11-13 20:25:58.308 - warn: node-red.0 (17987) 13 Nov 20:25:58 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:25:58 - [warn] [function:::LOG::] Payload
13 Nov 20:25:58 - [warn] [function:::LOG::] 256.3
13 Nov 20:25:58 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:25:58 - [warn] [function:::LOG::] true
2020-11-13 20:26:08.387 - warn: node-red.0 (17987) 13 Nov 20:26:08 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:26:08 - [warn] [function:::LOG::] Payload
13 Nov 20:26:08 - [warn] [function:::LOG::] 135.02
13 Nov 20:26:08 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:08 - [warn] [function:::LOG::] true
2020-11-13 20:26:18.509 - warn: node-red.0 (17987) 13 Nov 20:26:18 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:26:18.511 - warn: node-red.0 (17987) 13 Nov 20:26:18 - [warn] [function:::LOG::] Payload
13 Nov 20:26:18 - [warn] [function:::LOG::] 126.19
13 Nov 20:26:18 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:18 - [warn] [function:::LOG::] true
2020-11-13 20:26:28.552 - warn: node-red.0 (17987) 13 Nov 20:26:28 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:26:28.554 - warn: node-red.0 (17987) 13 Nov 20:26:28 - [warn] [function:::LOG::] Payload
13 Nov 20:26:28 - [warn] [function:::LOG::] 185.6
13 Nov 20:26:28 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:28 - [warn] [function:::LOG::] true
2020-11-13 20:26:38.635 - warn: node-red.0 (17987) 13 Nov 20:26:38 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:26:38.637 - warn: node-red.0 (17987) 13 Nov 20:26:38 - [warn] [function:::LOG::] Payload
13 Nov 20:26:38 - [warn] [function:::LOG::] 99.67
13 Nov 20:26:38 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:38 - [warn] [function:::LOG::] true
2020-11-13 20:26:48.718 - warn: node-red.0 (17987) 13 Nov 20:26:48 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:26:48.720 - warn: node-red.0 (17987) 13 Nov 20:26:48 - [warn] [function:::LOG::] Payload
13 Nov 20:26:48 - [warn] [function:::LOG::] 184.62
13 Nov 20:26:48 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:48 - [warn] [function:::LOG::] true
2020-11-13 20:26:58.840 - warn: node-red.0 (17987) 13 Nov 20:26:58 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:26:58.842 - warn: node-red.0 (17987) 13 Nov 20:26:58 - [warn] [function:::LOG::] Payload
13 Nov 20:26:58 - [warn] [function:::LOG::] 45.17
13 Nov 20:26:58 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:26:58 - [warn] [function:::LOG::] true
2020-11-13 20:27:08.888 - warn: node-red.0 (17987) 13 Nov 20:27:08 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:27:08.890 - warn: node-red.0 (17987) 13 Nov 20:27:08 - [warn] [function:::LOG::] Payload
13 Nov 20:27:08 - [warn] [function:::LOG::] 151.23
13 Nov 20:27:08 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:27:08 - [warn] [function:::LOG::] true
2020-11-13 20:27:29.063 - warn: node-red.0 (17987) 13 Nov 20:27:29 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:27:29.065 - warn: node-red.0 (17987) 13 Nov 20:27:29 - [warn] [function:::LOG::] Payload
13 Nov 20:27:29 - [warn] [function:::LOG::] 90.83
13 Nov 20:27:29 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:27:29 - [warn] [function:::LOG::] true
2020-11-13 20:27:39.119 - warn: node-red.0 (17987) 13 Nov 20:27:39 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:27:39.121 - warn: node-red.0 (17987) 13 Nov 20:27:39 - [warn] [function:::LOG::] Payload
13 Nov 20:27:39 - [warn] [function:::LOG::] 49.1
13 Nov 20:27:39 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:27:39 - [warn] [function:::LOG::] true
2020-11-13 20:27:49.200 - warn: node-red.0 (17987) 13 Nov 20:27:49 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:27:49 - [warn] [function:::LOG::] Payload
13 Nov 20:27:49 - [warn] [function:::LOG::] 71.69
2020-11-13 20:27:49.202 - warn: node-red.0 (17987) 13 Nov 20:27:49 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:27:49 - [warn] [function:::LOG::] true
2020-11-13 20:27:59.291 - warn: node-red.0 (17987) 13 Nov 20:27:59 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:27:59.293 - warn: node-red.0 (17987) 13 Nov 20:27:59 - [warn] [function:::LOG::] Payload
13 Nov 20:27:59 - [warn] [function:::LOG::] 90.83
13 Nov 20:27:59 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:27:59 - [warn] [function:::LOG::] true
2020-11-13 20:28:09.371 - warn: node-red.0 (17987) 13 Nov 20:28:09 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:09.373 - warn: node-red.0 (17987) 13 Nov 20:28:09 - [warn] [function:::LOG::] Payload
13 Nov 20:28:09 - [warn] [function:::LOG::] 47.63
13 Nov 20:28:09 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:09 - [warn] [function:::LOG::] true
2020-11-13 20:28:19.518 - warn: node-red.0 (17987) 13 Nov 20:28:19 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:19.520 - warn: node-red.0 (17987) 13 Nov 20:28:19 - [warn] [function:::LOG::] Payload
13 Nov 20:28:19 - [warn] [function:::LOG::] 52.05
13 Nov 20:28:19 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:19 - [warn] [function:::LOG::] true
2020-11-13 20:28:29.499 - warn: node-red.0 (17987) [warn] 2020-11-13 19:28:29.498 connection timed out, retrying...
2020-11-13 20:28:29.527 - warn: node-red.0 (17987) 13 Nov 20:28:29 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:29.529 - warn: node-red.0 (17987) 13 Nov 20:28:29 - [warn] [function:::LOG::] Payload
13 Nov 20:28:29 - [warn] [function:::LOG::] 58.43
13 Nov 20:28:29 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:29 - [warn] [function:::LOG::] true
2020-11-13 20:28:32.501 - warn: node-red.0 (17987) [warn] 2020-11-13 19:28:32.500 connection timed out, retrying...
2020-11-13 20:28:39.629 - warn: node-red.0 (17987) 13 Nov 20:28:39 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:39.631 - warn: node-red.0 (17987) 13 Nov 20:28:39 - [warn] [function:::LOG::] Payload
13 Nov 20:28:39 - [warn] [function:::LOG::] 90.34
13 Nov 20:28:39 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:39 - [warn] [function:::LOG::] true
2020-11-13 20:28:49.694 - warn: node-red.0 (17987) 13 Nov 20:28:49 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:49.695 - warn: node-red.0 (17987) 13 Nov 20:28:49 - [warn] [function:::LOG::] Payload
13 Nov 20:28:49 - [warn] [function:::LOG::] 101.64
13 Nov 20:28:49 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:49 - [warn] [function:::LOG::] true
2020-11-13 20:28:59.781 - warn: node-red.0 (17987) 13 Nov 20:28:59 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:28:59.783 - warn: node-red.0 (17987) 13 Nov 20:28:59 - [warn] [function:::LOG::] Payload
13 Nov 20:28:59 - [warn] [function:::LOG::] 77.09
13 Nov 20:28:59 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:28:59 - [warn] [function:::LOG::] true
2020-11-13 20:29:00.700 - warn: node-red.0 (17987) 13 Nov 20:29:00 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:29:00.701 - warn: node-red.0 (17987) 13 Nov 20:29:00 - [warn] [function:::LOG::] Payload
13 Nov 20:29:00 - [warn] [function:::LOG::] 77.09
13 Nov 20:29:00 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:29:00 - [warn] [function:::LOG::] true
2020-11-13 20:29:30.001 - warn: node-red.0 (17987) 13 Nov 20:29:30 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:29:30.003 - warn: node-red.0 (17987) 13 Nov 20:29:30 - [warn] [function:::LOG::] Payload
13 Nov 20:29:30 - [warn] [function:::LOG::] 106.55
13 Nov 20:29:30 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:29:30 - [warn] [function:::LOG::] true
2020-11-13 20:29:40.107 - warn: node-red.0 (17987) 13 Nov 20:29:40 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:29:40.109 - warn: node-red.0 (17987) 13 Nov 20:29:40 - [warn] [function:::LOG::] Payload
13 Nov 20:29:40 - [warn] [function:::LOG::] 130.12
13 Nov 20:29:40 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:29:40 - [warn] [function:::LOG::] true
2020-11-13 20:29:50.179 - warn: node-red.0 (17987) 13 Nov 20:29:50 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:29:50.181 - warn: node-red.0 (17987) 13 Nov 20:29:50 - [warn] [function:::LOG::] Payload
13 Nov 20:29:50 - [warn] [function:::LOG::] 153.19
13 Nov 20:29:50 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:29:50 - [warn] [function:::LOG::] true
2020-11-13 20:30:00.258 - warn: node-red.0 (17987) 13 Nov 20:30:00 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:30:00.259 - warn: node-red.0 (17987) 13 Nov 20:30:00 - [warn] [function:::LOG::] Payload
13 Nov 20:30:00 - [warn] [function:::LOG::] 178.23
13 Nov 20:30:00 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:30:00 - [warn] [function:::LOG::] true
2020-11-13 20:30:10.346 - warn: node-red.0 (17987) 13 Nov 20:30:10 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:30:10.347 - warn: node-red.0 (17987) 13 Nov 20:30:10 - [warn] [function:::LOG::] Payload
13 Nov 20:30:10 - [warn] [function:::LOG::] 200.33
13 Nov 20:30:10 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:30:10 - [warn] [function:::LOG::] true
2020-11-13 20:30:20.443 - warn: node-red.0 (17987) 13 Nov 20:30:20 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:30:20.445 - warn: node-red.0 (17987) 13 Nov 20:30:20 - [warn] [function:::LOG::] Payload
13 Nov 20:30:20 - [warn] [function:::LOG::] 221.44
2020-11-13 20:30:20.446 - warn: node-red.0 (17987) 13 Nov 20:30:20 - [warn] [function:::LOG::] waschmachineLäuft variable
2020-11-13 20:30:20.448 - warn: node-red.0 (17987) 13 Nov 20:30:20 - [warn] [function:::LOG::] true
2020-11-13 20:30:30.495 - warn: node-red.0 (17987) 13 Nov 20:30:30 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:30:30.496 - warn: node-red.0 (17987) 13 Nov 20:30:30 - [warn] [function:::LOG::] Payload
13 Nov 20:30:30 - [warn] [function:::LOG::] 236.17
13 Nov 20:30:30 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:30:30 - [warn] [function:::LOG::] true
2020-11-13 20:30:40.574 - warn: node-red.0 (17987) 13 Nov 20:30:40 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:30:40.578 - warn: node-red.0 (17987) 13 Nov 20:30:40 - [warn] [function:::LOG::] Payload
13 Nov 20:30:40 - [warn] [function:::LOG::] 275.45
13 Nov 20:30:40 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:30:40 - [warn] [function:::LOG::] true
2020-11-13 20:31:00.750 - warn: node-red.0 (17987) 13 Nov 20:31:00 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:31:00.752 - warn: node-red.0 (17987) 13 Nov 20:31:00 - [warn] [function:::LOG::] Payload
13 Nov 20:31:00 - [warn] [function:::LOG::] 233.23
13 Nov 20:31:00 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:31:00 - [warn] [function:::LOG::] true
2020-11-13 20:32:21.397 - warn: node-red.0 (17987) 13 Nov 20:32:21 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:32:21.400 - warn: node-red.0 (17987) 13 Nov 20:32:21 - [warn] [function:::LOG::] Payload
13 Nov 20:32:21 - [warn] [function:::LOG::] 360.39
13 Nov 20:32:21 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:32:21 - [warn] [function:::LOG::] true
2020-11-13 20:32:31.547 - warn: node-red.0 (17987) 13 Nov 20:32:31 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:32:31.548 - warn: node-red.0 (17987) 13 Nov 20:32:31 - [warn] [function:::LOG::] Payload
13 Nov 20:32:31 - [warn] [function:::LOG::] 290.18
13 Nov 20:32:31 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:32:31 - [warn] [function:::LOG::] true
2020-11-13 20:33:25.930 - error: node-red.0 (17987) 13 Nov 20:33:25 - [error] Error:
*** Bitte geben Sie an, wer Sie sind.
Führen Sie
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
aus, um das als Ihre standardmäßige Identität zu setzen.
Lassen Sie die Option "--global" weg, um die Identität nur
für dieses Repository zu setzen.
fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('iobroker@pi.(none)' erhalten)
at /opt/iobroker/node_modules/@node-red/runtime/lib/storage/localfilesystem/projects/git/index.js:37:19
2020-11-13 20:33:31.982 - warn: node-red.0 (17987) 13 Nov 20:33:31 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:33:31.985 - warn: node-red.0 (17987) 13 Nov 20:33:31 - [warn] [function:::LOG::] Payload
13 Nov 20:33:31 - [warn] [function:::LOG::] 405.08
13 Nov 20:33:31 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:33:31 - [warn] [function:::LOG::] true
2020-11-13 20:33:38.513 - warn: node-red.0 (17987) [warn] 2020-11-13 19:33:38.512 connection timed out, retrying...
2020-11-13 20:33:41.515 - warn: node-red.0 (17987) [warn] 2020-11-13 19:33:41.515 connection timed out, retrying...
2020-11-13 20:33:42.061 - warn: node-red.0 (17987) 13 Nov 20:33:42 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:33:42.064 - warn: node-red.0 (17987) 13 Nov 20:33:42 - [warn] [function:::LOG::] Payload
13 Nov 20:33:42 - [warn] [function:::LOG::] 462.03
13 Nov 20:33:42 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:33:42 - [warn] [function:::LOG::] true
2020-11-13 20:34:02.217 - warn: node-red.0 (17987) 13 Nov 20:34:02 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:34:02.219 - warn: node-red.0 (17987) 13 Nov 20:34:02 - [warn] [function:::LOG::] Payload
13 Nov 20:34:02 - [warn] [function:::LOG::] 407.53
13 Nov 20:34:02 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:34:02 - [warn] [function:::LOG::] true
2020-11-13 20:34:22.445 - warn: node-red.0 (17987) 13 Nov 20:34:22 - [warn] [function:::LOG::] Test Maschine läuft value
13 Nov 20:34:22 - [warn] [function:::LOG::] Payload
13 Nov 20:34:22 - [warn] [function:::LOG::] 178.72
13 Nov 20:34:22 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:34:22 - [warn] [function:::LOG::] true
2020-11-13 20:34:34.158 - warn: node-red.0 (17987) 13 Nov 20:34:34 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:34:34.160 - warn: node-red.0 (17987) 13 Nov 20:34:34 - [warn] [function:::LOG::] Payload
13 Nov 20:34:34 - [warn] [function:::LOG::] 21.35
13 Nov 20:34:34 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:34:34 - [warn] [function:::LOG::] true
2020-11-13 20:35:15.507 - warn: node-red.0 (17987) 13 Nov 20:35:15 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:35:15.509 - warn: node-red.0 (17987) 13 Nov 20:35:15 - [warn] [function:::LOG::] Payload
13 Nov 20:35:15 - [warn] [function:::LOG::] 20.46
13 Nov 20:35:15 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:35:15 - [warn] [function:::LOG::] true
2020-11-13 20:35:41.908 - warn: node-red.0 (17987) 13 Nov 20:35:41 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:35:41.911 - warn: node-red.0 (17987) 13 Nov 20:35:41 - [warn] [function:::LOG::] Payload
13 Nov 20:35:41 - [warn] [function:::LOG::] 2.21
13 Nov 20:35:41 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:35:41 - [warn] [function:::LOG::] true
2020-11-13 20:36:11.925 - warn: node-red.0 (17987) 13 Nov 20:36:11 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
13 Nov 20:36:11 - [warn] [function:::LOG::] 2.21
2020-11-13 20:36:41.940 - warn: node-red.0 (17987) 13 Nov 20:36:41 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
13 Nov 20:36:41 - [warn] [function:::LOG::] 2.21
2020-11-13 20:37:11.955 - warn: node-red.0 (17987) 13 Nov 20:37:11 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
2020-11-13 20:37:11.958 - warn: node-red.0 (17987) 13 Nov 20:37:11 - [warn] [function:::LOG::] 2.21
2020-11-13 20:37:41.968 - warn: node-red.0 (17987) 13 Nov 20:37:41 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
13 Nov 20:37:41 - [warn] [function:::LOG::] 2.21
2020-11-13 20:38:11.989 - warn: node-red.0 (17987) 13 Nov 20:38:11 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
13 Nov 20:38:11 - [warn] [function:::LOG::] 2.21
2020-11-13 20:38:42.006 - warn: node-red.0 (17987) 13 Nov 20:38:42 - [warn] [function:::LOG::] Neuer Wert Abgefragt (Überprüfung ob Maschine noch aus ist)
2020-11-13 20:38:42.009 - warn: node-red.0 (17987) 13 Nov 20:38:42 - [warn] [function:::LOG::] 2.21
2020-11-13 20:38:42.023 - warn: node-red.0 (17987) 13 Nov 20:38:42 - [warn] [function:::LOG::] Waschmaschine läuft nicht mehr
2020-11-13 20:38:42.025 - warn: node-red.0 (17987) 13 Nov 20:38:42 - [warn] [function:::LOG::] Pushover müsste jetzt eigentlich kommen
2020-11-13 20:38:47.522 - warn: node-red.0 (17987) [warn] 2020-11-13 19:38:47.521 connection timed out, retrying...
2020-11-13 20:38:50.525 - warn: node-red.0 (17987) [warn] 2020-11-13 19:38:50.524 connection timed out, retrying...
2020-11-13 20:41:47.869 - warn: node-red.0 (17987) 13 Nov 20:41:47 - [warn] [function:::LOG::] Test Maschine läuft value
2020-11-13 20:41:47.873 - warn: node-red.0 (17987) 13 Nov 20:41:47 - [warn] [function:::LOG::] Payload
13 Nov 20:41:47 - [warn] [function:::LOG::] 2.18
13 Nov 20:41:47 - [warn] [function:::LOG::] waschmachineLäuft variable
13 Nov 20:41:47 - [warn] [function:::LOG::] false
2020-11-13 20:43:56.539 - warn: node-red.0 (17987) [warn] 2020-11-13 19:43:56.538 connection timed out, retrying...
2020-11-13 20:43:59.542 - warn: node-red.0 (17987) [warn] 2020-11-13 19:43:59.542 connection timed out, retrying...
Regards
Try following the first part of the instructions here in setting up projects. I do not speak German so it is a little hard for me to see what the actual error is. But it is looking like you have not set up git correctly as it is showing a sample email in the error string.
https://knolleary.net/node-red-workshop-photobooth/part4/one-more-thing.html
joha91
19 November 2020 12:23
5
For me it did not work
Problem is still present. Also uninstall and installing GIT didn´t work
joha91
19 November 2020 17:57
6
Completely reinstalled Raspberry Pi OS, but it still does not work
