I'm using node-red quite a lot, and i'm planning to save all the logs that comes out from the nodes to a database, as i'm writing this post, i've learned how to create a custom log handler (settings.js) for the logs that comes to nodered and i'm able to save them to a Postgres database table, as shown below:
// Configure the logging output
logging: {
// Only console logging is currently supported
console: {
// Level of logging to be recorded. Options are:
// fatal - only those errors which make the application unusable should be recorded
// error - record errors which are deemed fatal for a particular request + fatal errors
// warn - record problems which are non fatal + errors + fatal errors
// info - record information about the general running of the application + warn + error + fatal errors
// debug - record information which is more verbose than info + info + warn + error + fatal errors
// trace - record very detailed logging + debug + info + warn + error + fatal errors
// off - turn off all logging (doesn't affect metrics or audit)
level: "info",
// Whether or not to include metric events in the log output
metrics: false,
// Whether or not to include audit events in the log output
audit: false
// Custom logger
psql: {
level: 'info',
metrics: true,
handler: function (settings) {
// Called when the logger is initialised
const Pool = require('pg').Pool
const pool = new Pool({
user: 'myuser',
host: 'db',
database: 'mydb',
password: 'mypass',
port: 5432,
// Return the logging function
return function (msg) {
console.log(msg);
pool.query('INSERT INTO node_log (data) VALUES ($1)', [msg], (error, results) => {
if (error) {
throw error
And this is the generated log:
mynodered | { level: 40, msg: 'Stopping flows', timestamp: 1562850905500 }
mynodered | 11 Jul 13:15:05 - [info] Stopped flows
mynodered | { level: 40, msg: 'Stopped flows', timestamp: 1562850905503 }
mynodered | 11 Jul 13:15:05 - [info] Starting flows
mynodered | { level: 40, msg: 'Starting flows', timestamp: 1562850905505 }
mynodered | 11 Jul 13:15:05 - [info] Started flows
mynodered | { level: 40, msg: 'Started flows', timestamp: 1562850905507 }
mynodered | { level: 99,
mynodered | nodeid: '77ec42e2.7dc2fc',
mynodered | event: 'node.inject.receive',
mynodered | msgid: '350414b5.4b64ac',
mynodered | value: undefined,
mynodered | timestamp: 1562850912684 }
mynodered | event: 'node.inject.send',
mynodered | timestamp: 1562850912685 }
mynodered | nodeid: '595ebe6d.50593',
mynodered | event: 'node.file.receive',
mynodered | event: 'node.file.send',
mynodered | timestamp: 1562850912688 }
mynodered | nodeid: 'c1a389bb.147b68',
mynodered | event: 'node.debug.receive',
mynodered | timestamp: 1562850912689 }
mynodered | event: 'runtime.memory.rss',
mynodered | value: 101470208,
mynodered | timestamp: 1562850912910 }
mynodered | event: 'runtime.memory.heapTotal',
mynodered | value: 74620928,
mynodered | timestamp: 1562850912912 }
mynodered | event: 'runtime.memory.heapUsed',
mynodered | value: 67069024,
mynodered | timestamp: 1562850912913 }
mynodered | timestamp: 1562850927917 }
Now, my goal is really simple: i want to identify the parent flow name of those nodes, and the name/description (or better, the icon that it's shown in the node) of the node, parse the data and make it usable for log debugging/event inspection in my web application.
Many thanks!
