Building a 3 element array from "form" and "dropdown" nodes to send on button click
Hello. I am trying to figure out the most logical way to build a 3 element payload array and out of form and dropdown nodes.
1 variable comes from "dropdown" node ( "Device")
2 variables comes from "form" node ("Item", "Serial").
I have initially built this flow:
However, with this flow I am facing a problem - whenever I select an item from dropdown menu, it immidiately sends an output signal to "join" node which is configured to count to 3. Another 2 variables come from "form" node. If an operator makes a mistake or needs to change the device from dropdown menu, it will automatically trigger another output signal and add +1 to the counter in join node which will only leave me 1 variable available which is not correct!
What I want to build instead, is a simmilar approach but instead, I would fill my array DBdata[2] with the variables from form and dropdown, and only send the data to the output when I press a button. I have tried to implement it here:
flow:
[{"id":"9d8656d9.cb81f8","type":"debug","z":"beb7a2a.0c08b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":850,"y":1900,"wires":[]},{"id":"7e41d220.32d40c","type":"mui_form","z":"beb7a2a.0c08b6","name":"","label":"Add data to MYSQL pack_to_light table test","group":"f9b77890.739788","order":2,"width":0,"height":0,"options":[{"label":"Item","value":"Item","type":"text","required":true,"rows":null},{"label":"Serial","value":"Serial","type":"number","required":true,"rows":null}],"formValue":{"Item":"","Serial":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":310,"y":1760,"wires":[["e351811f.0731","4ea178f0.80ad28"]]},{"id":"e5601425.fee918","type":"mui_dropdown","z":"beb7a2a.0c08b6","name":"","label":"Select device test","tooltip":"","place":"Select option","group":"f9b77890.739788","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"Device1","value":"Device1","type":"str"},{"label":"Device2","value":"Device2","type":"str"},{"label":"Device3","value":"Device3","type":"str"}],"payload":"","topic":"","x":250,"y":1680,"wires":[["b633b442.b45bc8"]]},{"id":"b633b442.b45bc8","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata[0]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":1680,"wires":[["9750fe28.a955d"]]},{"id":"e351811f.0731","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata[1]","pt":"flow","to":"payload.Item","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":1740,"wires":[["24f20766.7504e8"]]},{"id":"4ea178f0.80ad28","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata[2]","pt":"flow","to":"payload.Serial","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":1780,"wires":[["a782eb90.9ff0b8"]]},{"id":"e586ad95.c891e","type":"mui_button","z":"beb7a2a.0c08b6","name":"","group":"f9b77890.739788","order":4,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":230,"y":1900,"wires":[["2ff66de1.36f8e2"]]},{"id":"a782eb90.9ff0b8","type":"debug","z":"beb7a2a.0c08b6","name":"SErial","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":750,"y":1780,"wires":[]},{"id":"24f20766.7504e8","type":"debug","z":"beb7a2a.0c08b6","name":"Item","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":750,"y":1740,"wires":[]},{"id":"9750fe28.a955d","type":"debug","z":"beb7a2a.0c08b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":770,"y":1680,"wires":[]},{"id":"2ff66de1.36f8e2","type":"change","z":"beb7a2a.0c08b6","name":"Add 3 flows to build an array","rules":[{"t":"set","p":"payload[0]","pt":"flow","to":"DBdata[0]","tot":"flow"},{"t":"set","p":"payload[1]","pt":"flow","to":"DBdata[1]","tot":"flow"},{"t":"set","p":"payload[2]","pt":"flow","to":"DBdata[2]","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":1900,"wires":[["9512d53c.d579c8"]]},{"id":"9512d53c.d579c8","type":"debug","z":"beb7a2a.0c08b6","name":"combined","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":640,"y":1980,"wires":[]},{"id":"f9b77890.739788","type":"mui_group","name":"mGroup 1","tab":"5d85eb08.22c5a4","order":1,"disp":true,"width":6},{"id":"5d85eb08.22c5a4","type":"mui_tab","name":"Tab 2","icon":"dashboard","order":2}]
However, it does not seem to work as I have expected - it does not add the payloads when the button is pressed.
Switch node for each variable looks like this:
Switch node when button is pressed:
Join node:
Any ideas on how to make it work properly?
You may get quicker replies if you post the code as required.
Read this
Sorry! Fixed it now
Just mentioning:
You are using the MUI dashboard. That isn't the one most people use.
Therefore it is very difficult for anyone to test it for you, as they would have to un-install the existing dashboard and install that one.
If you are new to Node-Red, I would suggest you use the more common one:
This one.
Multiple people will be using the dashboard at the same time, that is why I have chose this one. I actually found out about this by accident and realized that this is exactly what I need. I think the only difference between MUI and the original one is that if a person change input variables on one instance, the other person will not be seeing those changes.
I'm not going to really comment on that.
I am simply saying: Most people here will not uninstall their dashboard to load the one you want to use.
IF people do use it, you are limiting the people who can help you.
[{"id":"9d8656d9.cb81f8","type":"debug","z":"beb7a2a.0c08b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":870,"y":1900,"wires":[]},{"id":"b633b442.b45bc8","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata.device","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":1680,"wires":[["9750fe28.a955d"]]},{"id":"e351811f.0731","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata.item","pt":"flow","to":"payload.Item","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":1740,"wires":[["24f20766.7504e8"]]},{"id":"4ea178f0.80ad28","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata","rules":[{"t":"set","p":"DBdata.serial","pt":"flow","to":"payload.Serial","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":1780,"wires":[["a782eb90.9ff0b8"]]},{"id":"a782eb90.9ff0b8","type":"debug","z":"beb7a2a.0c08b6","name":"SErial","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":1780,"wires":[]},{"id":"24f20766.7504e8","type":"debug","z":"beb7a2a.0c08b6","name":"Item","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":1740,"wires":[]},{"id":"9750fe28.a955d","type":"debug","z":"beb7a2a.0c08b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":790,"y":1680,"wires":[]},{"id":"2ff66de1.36f8e2","type":"change","z":"beb7a2a.0c08b6","name":"Add 3 flows to build an array","rules":[{"t":"set","p":"payload[0]","pt":"msg","to":"DBdata.device","tot":"flow"},{"t":"set","p":"payload[1]","pt":"msg","to":"DBdata.item","tot":"flow"},{"t":"set","p":"payload[2]","pt":"msg","to":"DBdata.serial","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":1900,"wires":[["9512d53c.d579c8"]]},{"id":"9512d53c.d579c8","type":"debug","z":"beb7a2a.0c08b6","name":"combined","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":680,"y":1900,"wires":[]},{"id":"7e9e942c.815e5c","type":"ui_dropdown","z":"beb7a2a.0c08b6","name":"","label":"select device","tooltip":"","place":"Select option","group":"e4811454.ed8328","order":5,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Device1","value":"Device1","type":"str"},{"label":"Device2","value":"Device2","type":"str"},{"label":"Device3","value":"Device3","type":"str"}],"payload":"","topic":"","x":260,"y":1620,"wires":[["b633b442.b45bc8"]]},{"id":"5d982d32.d36d14","type":"ui_form","z":"beb7a2a.0c08b6","name":"","label":"add data to mysql","group":"e4811454.ed8328","order":4,"width":0,"height":0,"options":[{"label":"Item","value":"Item","type":"text","required":true,"rows":null},{"label":"Serial","value":"Serial","type":"number","required":true,"rows":null}],"formValue":{"Item":"","Serial":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":270,"y":1760,"wires":[["4ea178f0.80ad28","e351811f.0731"]]},{"id":"e32bd3cc.34316","type":"ui_button","z":"beb7a2a.0c08b6","name":"","group":"e4811454.ed8328","order":3,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":250,"y":1940,"wires":[["2ff66de1.36f8e2"]]},{"id":"e4811454.ed8328","type":"ui_group","z":"","name":"TEST1","tab":"df4cfad1.0f1a18","order":1,"disp":true,"width":"6","collapse":false},{"id":"df4cfad1.0f1a18","type":"ui_tab","z":"","name":"Testing","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
This is the flow for original UI.
Also, you do not need to uninstall the original gui to use MUI. I am using both at the same time.
Well, that doesn't have the join node, so it is a waste of time posting when you say:
I'm outa here.
I was not sure if I even need join. If I add varaibles 1 by 1 to flow array and then just trying to print a whole array when button is pressed
I will try to clarify the problem. I have made slight changes:
flow:
[{"id":"b633b442.b45bc8","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata.device","rules":[{"t":"set","p":"DBdata[0]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1680,"wires":[["9750fe28.a955d"]]},{"id":"e351811f.0731","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata.item","rules":[{"t":"set","p":"DBdata[1]","pt":"flow","to":"payload.Item","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1740,"wires":[[]]},{"id":"4ea178f0.80ad28","type":"change","z":"beb7a2a.0c08b6","name":"set flow DBdata.serial","rules":[{"t":"set","p":"DBdata[2]","pt":"flow","to":"payload.Serial","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1780,"wires":[[]]},{"id":"9750fe28.a955d","type":"debug","z":"beb7a2a.0c08b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":930,"y":1680,"wires":[]},{"id":"2ff66de1.36f8e2","type":"change","z":"beb7a2a.0c08b6","name":"Add 3 flows to build an array","rules":[{"t":"set","p":"payload[0]","pt":"msg","to":"DBdata[0]","tot":"flow"},{"t":"set","p":"payload[1]","pt":"msg","to":"DBdata[1]","tot":"flow"},{"t":"set","p":"payload[2]","pt":"msg","to":"DBdata[2]","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1900,"wires":[["bd363f33.92efb"]]},{"id":"9512d53c.d579c8","type":"debug","z":"beb7a2a.0c08b6","name":"combined","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1040,"y":1900,"wires":[]},{"id":"bd363f33.92efb","type":"join","z":"beb7a2a.0c08b6","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":790,"y":1900,"wires":[["9512d53c.d579c8"]]},{"id":"3bd4ce44.193872","type":"ui_dropdown","z":"beb7a2a.0c08b6","name":"","label":"Select device test","tooltip":"","place":"Select option","group":"aef249c8.8ccee8","order":3,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"Device1","value":"Device1","type":"str"},{"label":"Device2","value":"Device2","type":"str"},{"label":"Device3","value":"Device3","type":"str"}],"payload":"","topic":"","x":330,"y":1680,"wires":[["b633b442.b45bc8"]]},{"id":"d4fea44a.990148","type":"ui_form","z":"beb7a2a.0c08b6","name":"","label":"Add data to mysql table test","group":"aef249c8.8ccee8","order":4,"width":0,"height":0,"options":[{"label":"Item","value":"Item","type":"text","required":true,"rows":null},{"label":"Serial","value":"Serial","type":"text","required":true,"rows":null}],"formValue":{"Item":"","Serial":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":360,"y":1760,"wires":[["e351811f.0731","4ea178f0.80ad28"]]},{"id":"f0aeda3f.18e048","type":"ui_button","z":"beb7a2a.0c08b6","name":"","group":"aef249c8.8ccee8","order":5,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":270,"y":1900,"wires":[["2ff66de1.36f8e2"]]},{"id":"aef249c8.8ccee8","type":"ui_group","z":"","name":"test123","tab":"bba97868.2e14a8","order":1,"disp":true,"width":"6","collapse":false},{"id":"bba97868.2e14a8","type":"ui_tab","z":"","name":"test123","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
"Switch"nodes to fill DBdata array:
If I submit form and dropdown tables, I should get:
DBdata[0] = Device1
DBdata[1] = Item1234
DBdata[2] = 1234
When I press button, DBdata array is converted to payload array data:
msg.payload[0]=Device1
msg.payload[1]=Item1234
msg.payload[2]=1234
When the button is clicked, I get an error:
msg : string[50]
"Cannot set property of non-object type: payload[0]"
I have also found out a new problem:
I have changed the switch function when the button is clicked to output msg.payload instead of payload array and the result is very strange. I am getting all kids of data ( even the data that I have not recently used as input) which implies that the DBdata is not cleared when i restart the flow. How to prevent this from happening?
