Button not sending `topic` as I see it
Although it is the button node, it is more to do with the message coming out of it.
This is the node code:
        "id": "89af2b10f87e66e9",
        "type": "ui_button",
        "z": "f6a2d75e7dd8f7ed",
        "group": "66644b9721f1197e",
        "order": 0,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "Start",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "TRIP",
        "payloadType": "str",
        "topic": "TRAIN",
        "topicType": "msg",
        "x": 350,
        "y": 370,
                "0f5725cd2cbfc233",
                "a5d2da0031c49502"
        "id": "66644b9721f1197e",
        "type": "ui_group",
        "name": "Control",
        "tab": "530b9cb957853dd9",
        "order": 1,
        "disp": true,
        "width": "3",
        "collapse": false,
        "className": ""
        "id": "530b9cb957853dd9",
        "type": "ui_tab",
        "name": "Track Singal NEW",
        "icon": "dashboard",
        "order": 43,
        "disabled": false,
        "hidden": false
The topic field is set to TRAIN.
But this is what I see when I press it:
Where's the topic?
Change the topic to string, not msg
Hi @Trying_to_learn Maybe you need to define first the msg.TRAIN property. Because you are asign msg.TRAIN to msg.topic, and msg.TRAIN is empty.
I share some examples:
Code:
[{"id":"ad061c48fbfd7f1a","type":"tab","label":"Flow 10","disabled":false,"info":"","env":[]},{"id":"7c08f886948a062c","type":"ui_button","z":"ad061c48fbfd7f1a","name":"","group":"1839522db6d21ee9","order":0,"width":0,"height":0,"passthru":true,"label":"button","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"TRIP","payloadType":"str","topic":"TRAIN","topicType":"str","x":850,"y":160,"wires":[["913cc5d5b3e72bcd"]]},{"id":"913cc5d5b3e72bcd","type":"debug","z":"ad061c48fbfd7f1a","name":"debug 14","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":980,"y":160,"wires":[]},{"id":"ec7f6b08633360bf","type":"inject","z":"ad061c48fbfd7f1a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":730,"y":160,"wires":[["7c08f886948a062c"]]},{"id":"94a47739bd802c06","type":"ui_button","z":"ad061c48fbfd7f1a","name":"","group":"1839522db6d21ee9","order":0,"width":0,"height":0,"passthru":true,"label":"button","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"TRIP","payloadType":"str","topic":"TRAIN","topicType":"msg","x":850,"y":100,"wires":[["a6bf3b5257831bab"]]},{"id":"a6bf3b5257831bab","type":"debug","z":"ad061c48fbfd7f1a","name":"debug 15","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":980,"y":100,"wires":[]},{"id":"760c8d269517f784","type":"inject","z":"ad061c48fbfd7f1a","name":"","props":[{"p":"payload"},{"p":"TRAIN","v":"this is the topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":730,"y":100,"wires":[["94a47739bd802c06"]]},{"id":"1839522db6d21ee9","type":"ui_group","name":"Default","tab":"7394f2f3aeaeeb2d","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"7394f2f3aeaeeb2d","type":"ui_tab","name":"Tab 1","icon":"dashboard","disabled":false,"hidden":false}]
I hope it can helps you!!
When did this get introduced?
It may explain why a lot of stuff has stopped working recently too. :frowning: :cry:
Thanks both for the replies.
Seems I really stuffed myself up there.
Appreciated.
I don't think the default setting has been changed, but in anycase it wouldn't alter any existing buttons
Well, maybe it hasn't "back rolled" to existing things, but I am writing a lot of stuff just now and it is failing hand over fist as in I am pressing buttons and things NOT happening.
I was simply doing what I always did and not seeing the qualifier has changed from text to msg so never even thought of seeing it.
(Familiarity blindness - I guess)
TBH I probably copy nodes more often than add new ones, so the text setting gets carried to the new node.
I'm torn doing that only in that if the structure (more so for function nodes than button nodes) it spreads bad formatting/code.
I would like to type things so I develop the muscle memory on how to do things the better way rather than copy/paste.
There can be nasty things propagated that way too.
But, I do get what you are saying.
