Button text not visible on first load
I'd appreciate some guidance on this issue.
I've a button which, for some reasons, doesn't show its text when loading for the first time the page. The text comes up once actioned the button and stays on.
How do I modify it.
TIA
        "id": "a8fd423c.f1f4f",
        "type": "rpi-gpio out",
        "z": "df2b4f99.163318",
        "name": "relayS",
        "pin": "33",
        "set": "",
        "level": "0",
        "freq": "",
        "out": "out",
        "x": 810,
        "y": 340,
        "id": "7f19db02.fc5264",
        "type": "ui_button",
        "name": "btnS",
        "group": "b7650ad6.bcc6",
        "order": 1,
        "width": "3",
        "height": "1",
        "passthru": false,
        "label": "{{msg.icon}}",
        "tooltip": "",
        "color": "white",
        "bgcolor": "{{msg.colour}}",
        "icon": "",
        "payload": "X",
        "payloadType": "str",
        "topic": "",
        "x": 570,
        "y": 280,
                "4bed650f.761c1c"
        "id": "4bed650f.761c1c",
        "type": "function",
        "name": "With icon on press",
        "func": "if (msg.payload == \"X\")\n{\n    //\n    //node.warn(\"X received\");\n    msg.payload = \"1\";\n\n    //msg.icon = '<font color = \"white\"><i class=\"material-icons md-48\"> check_circle_outline style:\"color:black\"></i></font>'\n    //msg.icon = '<i class=\"material-icons\"> check_circle_outline style:\"color:\"black\">';\n    //msg.icon = '<i class=\"material-icons\"> check_circle_outline</i>'\n    //msg.icon = '<font color = \"white\"><i class=\"material-icons\"> check_circle_outline</i></font>'\n    //msg  = {icon: '<font color = \"black\" i class=\"fa fa-book fa-2x\"></i>',\"payload\": \"Button pressed\"};\n}\nelse\n{\n    msg.payload = \"0\";\n    msg.icon  = \"Lavadora S\";\n    //msg  = {icon: '<font color = \"white\" i class=\"fa fa-book fa-2x\"></i>',\"payload\": \"Button released\"};\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 590,
        "y": 360,
                "7f19db02.fc5264",
                "b5e515d.94727e8",
                "a8fd423c.f1f4f"
        "id": "b5e515d.94727e8",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "1",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 810,
        "y": 400,
                "34f617a0.51a2e8"
        "id": "34f617a0.51a2e8",
        "type": "trigger",
        "op1": "",
        "op2": "Z",
        "op1type": "nul",
        "op2type": "str",
        "duration": "1",
        "extend": false,
        "overrideDelay": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 620,
        "y": 500,
                "4bed650f.761c1c"
        "id": "b7650ad6.bcc6",
        "type": "ui_group",
        "name": "Control",
        "tab": "ef5d65ce.36e6b",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": true
        "id": "ef5d65ce.36e6b",
        "type": "ui_tab",
        "name": "Washup",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
That is because you haven't done anything to cause the flow to start... until button press. Add in a single shot inject node to get it started
@Gunner. Thank you, it makes sense.
BTW, I learned a lot from you using your Blynk codes. I'm also leaving that project and exploring alternatives as Blynk v.2.0 doesn't support Python well.
Ok, I tried it but still not showing the text.
        "name": "relayS",
        "pin": "33",
        "set": "",
        "level": "0",
        "freq": "",
        "out": "out",
        "x": 810,
        "y": 340,
        "name": "btnS",
        "order": 1,
        "width": "3",
        "height": "1",
        "passthru": false,
        "tooltip": "",
        "color": "white",
        "icon": "",
        "payload": "X",
        "topic": "",
        "x": 570,
        "y": 280,
                "4bed650f.761c1c"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 590,
        "y": 360,
                "7f19db02.fc5264",
                "b5e515d.94727e8",
                "a8fd423c.f1f4f"
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "1",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 810,
        "y": 400,
                "34f617a0.51a2e8"
        "type": "trigger",
        "op1": "",
        "op2": "Z",
        "op1type": "nul",
        "op2type": "str",
        "duration": "1",
        "extend": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 620,
        "y": 500,
                "4bed650f.761c1c"
        "id": "f37771e39b154c0d",
        "type": "inject",
        "name": "tick 1",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "",
        "topic": "tempC",
        "x": 470,
        "y": 540,
                "7f19db02.fc5264"
        "type": "ui_group",
        "name": "Control",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": true
        "type": "ui_tab",
        "name": "Washup",
        "disabled": false,
        "hidden": false
I'm going to let you discover the issue yourself but give you a hint. What msg property is being used for the label and what msg properties are you sening it in the inject?
:sweat_smile: "Lavadora S"? In the label I've {{msg.icon}} which is "Lavadora S" in the function. So, I changed the inject node to reflect it with no avail.
Attach a debug node set to show complete message after the function what do you see in msg.icon?
Hint, your function conditionally sets msg.icon based on the incoming payload.
Ok, this' what I see:
output of inject: "Lavadora S" (as expected)
output of switch: Nothing!
output of function: Nothing!
Let's see your current flow
exactly my point. Look at the values and figure out why the msg isn't getting where it's supposed to
The only thing I'm trying to do here is a simple push-button which activates a relay for only a second. I just created a new clean flow in case the rest of the code was affecting the button.
        "id": "d2d5d2de2e29a4b5",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": ""
        "z": "d2d5d2de2e29a4b5",
        "name": "btnS",
        "order": 1,
        "width": "3",
        "height": "1",
        "passthru": false,
        "tooltip": "",
        "color": "white",
        "className": "",
        "icon": "",
        "payload": "X",
        "topic": "",
        "topicType": "str",
        "x": 390,
        "y": 60,
                "4bed650f.761c1c",
                "38cf180271591a5e"
        "type": "function",
        "func": "if (msg.payload == \"X\")\n{\n    //\n    //node.warn(\"X received\");\n    msg.payload = \"0\";\n\n    //msg.icon = '<font color = \"white\"><i class=\"material-icons md-48\"> check_circle_outline style:\"color:black\"></i></font>'\n    //msg.icon = '<i class=\"material-icons\"> check_circle_outline style:\"color:\"black\">';\n    //msg.icon = '<i class=\"material-icons\"> check_circle_outline</i>'\n    //msg.icon = '<font color = \"white\"><i class=\"material-icons\"> check_circle_outline</i></font>'\n    //msg  = {icon: '<font color = \"black\" i class=\"fa fa-book fa-2x\"></i>',\"payload\": \"Button pressed\"};\n}\nelse\n{\n    msg.payload = \"1\";\n    msg.icon  = \"Lavadora S\";\n    //msg  = {icon: '<font color = \"white\" i class=\"fa fa-book fa-2x\"></i>',\"payload\": \"Button released\"};\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 410,
        "y": 140,
                "b5e515d.94727e8",
                "7f19db02.fc5264"
        "type": "switch",
        "rules": [
                "t": "eq",
                "v": "1",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 610,
        "y": 200,
                "34f617a0.51a2e8"
        "type": "trigger",
        "op1": "",
        "op2": "Z",
        "op1type": "nul",
        "op2type": "str",
        "duration": "1",
        "extend": false,
        "units": "s",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 420,
        "y": 300,
                "4bed650f.761c1c"
        "id": "38cf180271591a5e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 690,
        "y": 140,
        "id": "56a729ec83d2fc27",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "\"Lavadora S\"",
        "x": 170,
        "y": 60,
                "7f19db02.fc5264"
        "type": "ui_group",
        "name": "Control",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": true
        "type": "ui_tab",
        "name": "Washup",
        "disabled": false,
        "hidden": false
I understand but the output of the payload for the button is "X" and that is not shown either :expressionless:
Look at your inject note. What msg proberty are you setting Lavadora S` to and what msg property is the button label expectring to see the value in?
The string "X" but... no go.
However, if I inject "X" to the function, it starts to loop with:
msg : Object
object
_msgid: "45b5662835d1e281"
payload: "1"
topic: ""
icon: "Lavadora S"
  1. in the ui-button node what are you using to display the label - What did you enter in the label configuration?
  2. looking at that what part of the msg are you using?
  3. go to the inject node and look at what part of the msg you are putting 'Lavadora S` in.
This' what I have:
So - once again - what msg property is the button using?
Is that property being set in the inject node?
The answer is staring at you.
You mean I should use "{{msg.icon}}" in the inject node? I'm not seeing the tree in the forest, sorry. I've been dealing with this issue some time now and I didn't realize the complex is to create a simple push-button.
If you are using msg.icon in the button, in the inject node you have to set msg.icon to some value. You are putting your label in msg.payload so it won’t be used.
Just to let you know, I have done something like this more than once asnd always groan when I realise I've done it again :flushed:
