Button vibrate in dashboard2
Hi in dashboard-1 I had a template button with..
<md-button class="vibrate filled touched smallfont rounded"
which gave a haptic feedback on my mobile phone. Is there an equivalent in DB2?
thanks
Hi @muggins,
I have not tried it, but step 3 from this article 'might' be what you need:
<template>
  <button @click="vibrate">Click me!</button>
</template>
<script>
export default {
  methods: {
    vibrate() {
      window.navigator.vibrate(200); // Vibrate for 200ms
</script>
It uses the vibrate API, which they claim is offered by most modern browsers.
Bart
Thanks for that. I'll check it out.
Got it working and sending a payload.... thanks again
Don't forget that you should really check first to see if the client browser actually supports window.navigator.vibrate. Unless you know for sure what browsers will be in use.
Glad to hear!!
It would be nice if you could export an example flow and share it here, so others can easily test it.
Works nicely on my Samsung phone
        "id": "11630dfec7c7118d",
        "type": "debug",
        "z": "8c28c548e9dc1527",
        "name": "debug 8",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1320,
        "y": 1380,
        "id": "ac05354da95eb10e",
        "type": "ui-template",
        "group": "cc05ce8b40f451e3",
        "page": "",
        "ui": "",
        "name": "Click_vibrate",
        "order": 0,
        "width": "3",
        "height": "1",
        "head": "",
        "format": "<template>\n<v-btn @click=\"vibrate\" \nrounded=\"xl\" size=\"large\" color=\"yellow\" >\nClick me\n</v-btn>\n</template>\n\n<script>\nexport default {\n  methods: {\n    vibrate() {\n      this.send({topic: 'myTopic',payload: 'myPayload'})\n      window.navigator.vibrate(200); // Vibrate for 200ms\n    }\n  }\n}\n</script>\n\n\n\n\n",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 1110,
        "y": 1380,
                "11630dfec7c7118d"
        "id": "cc05ce8b40f451e3",
        "type": "ui-group",
        "name": "humiG",
        "page": "b13a3963679b7287",
        "width": "6",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "b13a3963679b7287",
        "type": "ui-page",
        "name": "humi",
        "ui": "255a505aeaa8f56b",
        "path": "/humi",
        "icon": "home",
        "layout": "grid",
        "theme": "9273d2fc8b92c1dd",
        "order": 3,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "255a505aeaa8f56b",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "showPageTitle": true,
        "navigationStyle": "default",
        "titleBarStyle": "hidden"
        "id": "9273d2fc8b92c1dd",
        "type": "ui-theme",
        "name": "Default",
        "colors": {
            "surface": "#404040",
            "primary": "#109fbc",
            "bgPage": "#e8e8e8",
            "groupBg": "#d6d6d6",
            "groupOutline": "#6fbc10"
        "sizes": {
            "pagePadding": "0px",
            "groupGap": "0px",
            "groupBorderRadius": "0px",
            "widgetGap": "0px"
