Depending on the time of day, the light in the loo is turned on at modest or minimal brightness. On a long-press, it'll go to max brightness. In either case, the light turns off after 10 minutes. That's working fine.
I added that long-press/max brightness for when I'm cleaning, but 10 minutes is not enough.
I could just up the trigger time, but the 10 minutes is already a bit too long for most bathroom visits.
Is there some way to disable/ignore the trigger node when the long-press is received?
Edit:
Almost immediately after posting this, my own light-bulb came on and I came up with a workable solution for the 'long press light needs to stay on indefinitely' by adding a second trigger which retriggers the '10 minute' trigger every 5 minutes, therefore extending the timer.
I am, however, still wondering if there is a way to bypass/ignore a node based on a given input.
