aside from bringing a msg into a function node and sending a msg out at the end of a function, how can i call a function from within a function?
in the middle of my function i need to perform some numerical computes that i can either copy and paste the same formulas throughout my functions or i can call a function.
I did write a function and saved it to a function library, but i don't see how to call it. (node.send?). I may need to call the same function 10 times within the function.
In my searches i see talk about 'sub flows'., but how is the 'return' implemented? is a sub flow wired or called?
A subflow is wired the same as any node. The beauty of using a subflow is your function code exists only once (i.e. not an unmanageable 10 copy/paste affair).
Pass your data to input of subflow, get processed data out of its output(s)
If you want to stay totally inside the one function you can just declare an internal function just like in any other piece of javascript. var myfunc = function(foo) {... style then call it from within your function.
Things to note are that the whole function is instantiated whenever a msg arrives so you if you need to maintain some context you must remember to do that.
Thank you dceejay,
i'm not sure where i read it, but is it possible to declare a function as you stated as a 'global variable' where i change a memory config in settings.js?
You can declare functions in global. But it isn't wise to do that within a flow, only from settings.js
That is because not all var handlers may support serialisation of functions.
But setting in the globals section of settings.js should always work. You can then use `global.get('myfnName') in a function node to get a reference to the function.
do i simply add the function declaration at the end of the settings file?
function myFunction(n1,n2) {
return n1 + n2;
var input = msg;
var off = input.payload.foff;
var on = input.payload.fon;
var count = 1;
var input_off_float = flow.get(["input_off_float"]);
var ttltimeofffloatoff, ttltimeofffloaton, difference, calcdifference, testf ;
var d = new Date();
var timestamp1, timestamp2;
var newfunction = global.get('myFunction');
timestamp1 = d.getTime();
if(input_off_float == 2){
on=on+count; // increase count variable to write back to lifetime counter
timestamp2 = global.get(["offfloatlaststoptime"]); // get the last time off float went off to compute how long float has been off
difference = timestamp1 - timestamp2; // computes the difference using epoch time
calcdifference = parseInt(difference/1000);
flow.set(["difference"],difference); // sets difference to actual difference in milliseconds
flow.set(["ttltimeofffloaton"],calcdifference); // gives us seconds for total time off float to on
testf = newfunction(difference, 5);
flow.set(["testf"],testf);
else if (input_off_float == 3){
off=off+count; // increase count variable to write back to lifetime counter
timestamp2 = global.get(["onfloatlaststoptime"]); // get the global variable storing the last time the on float went to off status
flow.set(["ttltimetopumpfromhighfloat"],calcdifference); // set the total time var for the pump to empty
testf = newfunction(difference, 10);
flow.set(["on"],on);
flow.set(["off"],off);
msg.payload.foff = off;
msg.payload.fon = on;
this is my console output
22 Apr 17:40:10 - [error] [function:reads count file updates count writes back] TypeError: newfunction is not a function
I feel like i am close, but what am i missing?
thanks for your time...
