I need to call a server API to POST some data in custom node's js file. I am trying to use "node-fetch" , but it always gives me " Cannot find module 'node-fetch'" I have installed the module. Module is available under "node_modules" folder.
I am using below line of code to test a simple server call:
const fetch = require('node-fetch');
fetch("some_url").then(res => console.log(res.text()))
.then(body => console.log(body));
Could you please suggest. Also is it a right way to do this?
Which folder contains the node_modules folder that contains node-fetch?
When posting code, please follow the forum instractions and wrap the code in back-ticks so that it is more readable thanks.
Where are you putting that code? If it is in a function node, you can't use require() because a function node uses a Node.js VM which prevents its use.
Instead you have to do the require in your node-red settings.js file assigning the output to the globals section. Then in your function you will have something like:
const fetch = global.get('fetch');
Where 'fetch' will be the name you assigned the require() to in settings.js.
