Hello Everyone,
I am building a flow that contains a large amount of subflows. Within these subflows you find one node named ArrayDefect"X". X being an identifier. I have to set these array for each individual machine that I add to this flow. We have around 80+ machines at our plant.
QUESTION: Is there a way to use an environment variable or pass a variable on to the end of these nodes that I can specify per subflow as a 1, 2, 3, 4, etc. ? That way when I just copy and paste all I have to do is add an environment variable of the number I want and just reference that number? I know its possible to set a environment variable in the value field but is it possible in the naming field?
Thank you!
