good day
can anybody tell me what node i can use to switch on a relay for 3 seconds
Trigger node (and something to start the flow like a UI button or inject node)
E.g.
Inject > trigger > your-relay-node
Here is how I control one of my blinds by activating a relay that simulates a press on the remote control button
[{"id":"2ae520f2e33428fd","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"bb898f1fbb7cf2f6","type":"delay","z":"2ae520f2e33428fd","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":460,"y":180,"wires":[["1006b2767f798513"]]},{"id":"039e470f5f32386d","type":"mqtt out","z":"2ae520f2e33428fd","name":"Relais 6","topic":"cmnd/ESP-Stores/POWER3","qos":"","retain":"","broker":"702ec46.d6e003c","x":740,"y":160,"wires":[]},{"id":"1006b2767f798513","type":"function","z":"2ae520f2e33428fd","name":"OFF","func":"msg.payload = 'OFF'\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":180,"wires":[["039e470f5f32386d"]]},{"id":"59a7628d3f584be7","type":"function","z":"2ae520f2e33428fd","name":"ON","func":"msg.payload = 'ON'\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":160,"wires":[["039e470f5f32386d","bb898f1fbb7cf2f6"]]},{"id":"332531dab392cc3e","type":"switch","z":"2ae520f2e33428fd","name":"Store Sud","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":160,"y":180,"wires":[["59a7628d3f584be7"],[]]},{"id":"702ec46.d6e003c","type":"mqtt-broker","name":"MQTT-Debian64","broker":"192.168.1.160","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
I'm new to this and i'm trying to automate my house please give more detail on how to use this sring of code
thank you but please tell me how to set up (Inject > trigger > your-relay-node) im new to this and trying to automate my house as a project
open your flow editor, go to the top right menu, click on "Import" and paste the example I gave you. Then you can study how it works by opening each node. This is very telling by itself.
ok thank you i will try
now im having a problem opening node-red it cant connect to server
what happens when you run the node-red-start command from the console? Please put a screenshot
