I am running my node-red in a docker and am happy with tons of working flows. I would like to generate some debug-information and send it out to a syslog/graylog server. I have search the net but am only able to find working solutions for node-red receive syslog messages but I want to SEND them. Any ideas?
Regards
JP
You can just use UDP/TCP node to send to syslog.
If you need help formatting the messages, then there is this: node-red-contrib-syslog (node) - Node-RED
This node will format msg.payload as a valid syslog message which can be sent to a syslog server via a UDP or TCP node.
That's what I figured after investigating a bit further but for whatever reason it did not work but now it does. Thanks!
