Can I use different port for websocket comms
You know the phrase - there's no such thing as a stupid question....
I know how to spell websickets but that's about as far as it goes but I've managed to get a Scratch extension to connect to a websocket listener (if thats the right terminology) running on Node-RED
JS code in my Scratch3 extension
Can I use a different socket from 1880?
Is so - whats the the syntax/config to change it to using port 9000?
No, you cannot. It only knows how to listen on the same server as Node-RED.
You could change Node-RED to listen on port 9000, but then you access it all on that port, including the editor. That's done via the settings file.
Ta :slight_smile:
I'll run up one of @TotallyInformation alternative instances running on 9000
RESULT :slight_smile:
Is there a particular reason that you are using scratch and trying to connect it with NR? There is a blockly node available for NR that will allow you to use that programming interface directly in Node-red instead of a function node. Just FYI.
node-red-contrib-blockly
:slight_smile:
I've spent quite a considerable amount of my programming life using Scratch and developing extensions for it - see simplesi.net
I use it all the time in my flows :slight_smile:
