Hi, sir
Here is my code, and it is strange that the hint color is changed to orange in VPlay, however the hint color remains the same in my dashboard2.
Pls find this picture for the difference:
<template>
<div class="wrapperPara" ref="wrapper">
<v-card v-for="(parameter,index) in item.paraItems" :key="index" ref="cards" class="cardPara">
<v-card-text class="card-contentPara">
<div class="containerPara">.
<div class="leftPara">
<i class="iconPara">{{ item.houseIcon }}</i>
</div>
<div class="middlePara">
<div class="titlePara">{{ parameter.name }}</div>
<div v-if="parameter.name!=='variable' && parameter.name!=='signal' "class="control-row">
<button class="btnPara" :style="{ height:'25px', backgroundColor: parameter.isFixedValue ? '#90a4ae' : 'rgb(0, 204, 255)' }" @click="onFixed(index)">FIXED VALUE</button>
<button class="btnPara" :style="{ height:'25px', backgroundColor: parameter.isFixedValue ? 'rgb(0, 204, 255)':'#90a4ae' }" @click="onVariable(index)">VARIABLE</button>
</div>
<div v-if="(parameter.name!=='variable' && parameter.name!=='signal') && parameter.isFixedValue===false " class="control-row">
<v-text-field v-model="parameter.value" hint="Please input the value" persistent-hint class="paramsPara"></v-text-field>
<v-text-field readonly class="paramsPara2">
mm/s
</v-text-field>
</div>
<div v-else class="control-row">
<v-select hint="Plsease select the item" persistent-hint :items="variableNames" class="paramsPara">
</v-select>
</div>
</div>
</div>
</v-card-text>
</v-card>
</div>
</template>
<script>
export default {
data() {
return {
variableNames:
'variable1',
'variable2'
item:
title: "Init position",
houseIcon: "🏠",
paraItems:[
type: "INPUT",
value: 100,
isFixedValue: true
type: "INPUT",
value: 1000,
isFixedValue: true
methods: {
// Initialize the value
makeItem(payload) {
this.item.id=payload.id;
this.item.title= payload.title;
this.item.houseIcon= payload.houseIcon;
this.item.locationIcon= payload.locationIcon;
this.item.paraItems=[];
payload.paraItems.forEach((item, idx) => {
this.item.paraItems.push(
type: item.type,
value: item.value,
isFixedValue: false
// Select the card
onFixed(index) {
this.item.paraItems[index].isFixedValue = false;
onVariable(index) {
this.item.paraItems[index].isFixedValue = true;
mounted() {
//this.layoutGrid();
watch: {
msg: function ()
if(this.msg.topic==="New parameters")
this.makeItem(this.msg.payload);
deep:true
</script>
<style scoped>
.wrapperPara {
flex-direction: coloumn;
align-items: flex-start;
width: 100%;
gap: 10px;
overflow-y: auto;
height: 100%;
position: relative;
border: none;
.cardPara {
width: 100%;
height: 150px;
padding: 0;
border: none;
.card-contentPara {
display: flex;
flex: 1;
width: 100%;
height: 100%;
padding: 0;
.containerPara {
display: flex;
align-items: center;
margin: 0;
width: 100%;
padding: 0;
border: none;
font-family: Arial, sans-serif;
background: #fff;
cursor: pointer;
transition: all 0.2s ease;
justify-content: space-between;
padding: 8px;
position: relative;
.leftPara {
flex: 0 0 auto;
display: flex;
margin-right: 10px;
.iconPara {
margin: 0 3px;
font-size: 14px;
.middlePara {
flex: 1;
flex-direction: column;
.titlePara {
font-weight: bold;
margin-bottom: 5px;
font-size: 20px;
.control-row {
display: flex;
width: 100%;
justify-content: center;
.paramsPara {
flex: 4;
font-size: 13px;
color: #444;
margin:0;
.paramsPara:deep(.v-messages__message) {
color: #ff9800 !important;
.paramsPara2 {
flex: 1;
font-size: 13px;
.btnPara {
flex: 1;
color:white;
font-weight: bold;
font-size: 16px;
min-width: 0;
</style>
