@Loveflowersx one thing to note is that the text-input node is going to send what ever is in the input every 300ms (the default value. This means if you. have a slow typer, you will see bits the text sent as time goes on.
In this case, you might want to use the ui-form node and set an entry as type 'E-mail', then the address will not be sent until the user presses 'SUBMIT'
Please export your flow and post it to a response.
code goes here
icon.
