Cannot display values in UI Template
This function is retrieving some value from context:
let data = {
    totalZeroHoursYear: flow.get("totalZeroHoursYear") || "N/A",
    totalZeroHoursMonth: flow.get("totalZeroHoursMonth") || "N/A",
    totalZeroHoursWeek: flow.get("totalZeroHoursWeek") || "N/A",
    totalZeroHoursYesterday: flow.get("totalZeroHoursYesterday") || "N/A",
    totalZeroHoursToday: flow.get("totalZeroHoursToday") || "N/A"
msg.payload = data;
The output is an object:
23/01/2024, 05:47:32node: debug 316
msg.payload : Object
object
totalZeroHoursYear: "42.39"
totalZeroHoursMonth: "42.39"
totalZeroHoursWeek: "0.96"
totalZeroHoursYesterday: "0.96"
totalZeroHoursToday: "0.00"
A template node is connected to the output of the above function:
<div style="text-align: left; font-size: 18px; margin-top: 10px;">
    <p><b>Power Outage Duration:</b></p>
    <p>Year: {{payload.totalZeroHoursYear}} hours</p>
    <p>Month: {{payload.totalZeroHoursMonth}} hours</p>
    <p>Week: {{payload.totalZeroHoursWeek}} hours</p>
    <p>Yesterday: {{payload.totalZeroHoursYesterday}} hours</p>
    <p>Today: {{payload.totalZeroHoursToday}} hours</p>
</div>
It looks all correct to me but I cannot display the values on the UI:
The value shows up if I use a text node instead of a template with value set as {{msg.payload.totalZeroHoursYear}} hours etc.
I would appreciate som help to get this working in the template node. Thank you
I found the issue.
this:
should be like this:
Year: {{msg.payload.totalZeroHoursYear}} hours
Just in case someone has a similar issue.
