Can't Find Serial Node in Node-Red
Hello. I am very new to node-red and have a trouble finding the serial node (serial in, serial out, and serial request). I had searched them in the drawer in the left hand side but still couldn't find them. I tried to install node-red-node-serialport module to fix the problem but i got error. Here are the logs:
2021-11-08T17:09:26.887Z Install : node-red-node-serialport 0.14.1
2021-11-08T17:09:27.174Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-node-serialport@0.14.1
2021-11-08T17:10:34.446Z [out]
2021-11-08T17:10:34.446Z [out] > @serialport/bindings@9.2.5 install C:\Users\DELL\.node-red\node_modules\@serialport\bindings
2021-11-08T17:10:34.446Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2021-11-08T17:10:36.978Z [err] prebuild-install
2021-11-08T17:10:36.978Z [err]  WARN install No prebuilt binaries found (target=14.17.5 runtime=node arch=x64 libc= platform=win32)
2021-11-08T17:10:37.032Z [out]
2021-11-08T17:10:37.032Z [out] C:\Users\DELL\.node-red\node_modules\@serialport\bindings>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python Python is not set from command line or npm configuration
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python Python is not set from environment variable PYTHON
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if "python" can be used
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "python" is not in PATH or produced an error
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if "python2" can be used
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "python2" is not in PATH or produced an error
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if "python3" can be used
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "python3" is not in PATH or produced an error
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if the py launcher can be used to find Python 2
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "py.exe" is not in PATH or produced an error
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if Python is C:\Python27\python.exe
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "C:\Python27\python.exe" could not be run
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python checking if Python is C:\Python37\python.exe
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - "C:\Python37\python.exe" could not be run
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python **********************************************************
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python You need to install the latest version of Python.
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python you can try one of the following options:
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python   (accepted by both node-gyp and npm)
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - Set the environment variable PYTHON
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python - Set the npm configuration variable python:
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python For more information consult the documentation at:
2021-11-08T17:10:46.623Z [err] gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
2021-11-08T17:10:46.623Z [err] gyp ERR! configure error
2021-11-08T17:10:46.623Z [err] gyp ERR! stack Error: Could not find any Python installation to use
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at exithandler (child_process.js:397:5)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:409:5)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at onErrorNT (internal/child_process.js:467:16)
2021-11-08T17:10:46.623Z [err] gyp ERR! stack     at processTicksAndRejections (internal/process/task_queues.js:82:21)
2021-11-08T17:10:46.623Z [err] gyp ERR! System Windows_NT 10.0.19042
2021-11-08T17:10:46.623Z [err]  ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
2021-11-08T17:10:46.623Z [err] gyp ERR! cwd C:\Users\DELL\.node-red\node_modules\@serialport\bindings
2021-11-08T17:10:46.623Z [err] gyp ERR! node -v v14.17.5
2021-11-08T17:10:46.623Z [err] gyp ERR! node-gyp -v v5.1.0
2021-11-08T17:10:46.623Z [err] gyp ERR! not ok
2021-11-08T17:10:47.442Z [err] npm
2021-11-08T17:10:47.443Z [err]  ERR! code
2021-11-08T17:10:47.443Z [err]  ELIFECYCLE
2021-11-08T17:10:47.443Z [err] npm
2021-11-08T17:10:47.444Z [err] ERR! errno 1
2021-11-08T17:10:47.456Z [err] npm
2021-11-08T17:10:47.456Z [err] ERR! @serialport/bindings@9.2.5 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
2021-11-08T17:10:47.456Z [err] npm ERR! Exit status 1
2021-11-08T17:10:47.456Z [err] npm ERR! Failed at the @serialport/bindings@9.2.5 install script.
2021-11-08T17:10:47.456Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2021-11-08T17:10:47.542Z [err]
2021-11-08T17:10:47.542Z [err] npm ERR! A complete log of this run can be found in:
2021-11-08T17:10:47.542Z [err] npm ERR!     C:\Users\DELL\AppData\Roaming\npm-cache\_logs\2021-11-08T17_10_47_463Z-debug.log
2021-11-08T17:10:47.588Z rc=1
My node-red version is v2.1.3
My node js version is v14.17.5
Any help is appreciated.
Welcome to the forum @fajar.r.w
Please read the node red docs pages for getting started with Windows and it will tell you how to install the Window Build Tools that you need for some nodes.
https://nodered.org/docs/getting-started/windows
