i changed the default settings.js to save variables in file system. i do it in this way
var value = 1;
context.set('value',value,"file"); // ✅ Store value in context
msg.payload = {
"value": value
i can see them also in docker container.
but when i try to get the value from file system i get undefined.
function node for getting value from file looks like this
var value = context.get("value","file"); //without file also didnt work
msg.payload = {
"value": value
as returned msg.payload object i become;
msg.payload : Object
object
value: undefined
why cant i get the value which is saved in container?
Colin
9 February 2025 17:08
2
Does it fetch the value if you do it without restarting node-red, or is it only after a restart that it fails?
E1cid
9 February 2025 17:29
3
Is this in the same function node as context is node based.
If you alter the function node the context for the node is deleted.
Try with flow context
It didnt work even i restart or not. The solution was using flow.get, flow.set instead of using content.get content.set
i dont know why but it worked with flow.get, flow.set. Thanks
E1cid
9 February 2025 17:57
7
As said
Context is node specific if you rewrite the function node the context is reset. You can only retrieve context from the function node that saved it, unless you alter that function node and redeploy.
Flow is flow specific, so is not reset when you alter the function node.
https://nodered.org/docs/user-guide/context
