Cant re-install the midi module
hello i was use the node red midi for send and receive the midi message before but now i cant install the mid module :slight_smile:
i dont know what is actually module :
1- node-red-contrib-midi-windows (node) - Node-RED
2 - node-red-contrib-midi (node) - Node-RED
Microsoft Windows [Version 10.0.19045.3693]
(c) Microsoft Corporation. All rights reserved.
C:\Users\AmirGhorbani>npm install node-red-contrib-midi
added 5 packages, and audited 326 packages in 13s
46 packages are looking for funding
run npm fund for details
5 vulnerabilities (2 moderate, 3 high)
To address all issues (including breaking changes), run:
npm audit fix --force
Run npm audit for details.
C:\Users\AmirGhorbani>npm audit
npm audit report
got <=11.8.3
Severity: high
Got allows a redirect to a UNIX socket -
Depends on vulnerable versions of cacheable-request
fix available via npm audit fix --force
Will install nexe@1.1.6, which is a breaking change
node_modules/download/node_modules/got
download >=4.0.0
Depends on vulnerable versions of got
nexe >=2.0.0-beta.1
Depends on vulnerable versions of download
node_modules/nexe
http-cache-semantics <4.1.1
Severity: high
http-cache-semantics vulnerable to Regular Expression Denial of Service -
node_modules/download/node_modules/http-cache-semantics
cacheable-request 0.1.0 - 2.1.4
Depends on vulnerable versions of http-cache-semantics
node_modules/download/node_modules/cacheable-request
C:\Users\AmirGhorbani>npm audit fix --force
npm WARN using --force Recommended protections disabled.
npm WARN audit Updating nexe to 1.1.6, which is a SemVer major change.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see
added 219 packages, removed 168 packages, changed 10 packages, and audited 377 packages in 24s
39 packages are looking for funding
npm audit report
request *
Severity: moderate
Server-Side Request Forgery in Request -
Depends on vulnerable versions of tough-cookie
Will install nexe@4.0.0-rc.4, which is a breaking change
node_modules/request
nexe 0.1.0 - 1.1.6
Depends on vulnerable versions of request
Depends on vulnerable versions of yargs
node_modules/nexe
tough-cookie <4.1.3
Severity: moderate
tough-cookie Prototype Pollution vulnerability -
node_modules/tough-cookie
yargs-parser <=5.0.0
Severity: moderate
yargs-parser Vulnerable to Prototype Pollution -
node_modules/yargs-parser
yargs 4.0.0-alpha1 - 7.0.0-alpha.3 || 7.1.1
Depends on vulnerable versions of yargs-parser
node_modules/yargs
5 moderate severity vulnerabilities
Welcome to forums @AmirGhorbani
You are not running the command in the right place for starters.
any reason you're not installing them from within the Node RED pallete manager?
if doing it via command prompt, you need to cd into C:\Users\AmirGhorbani\.node-red
and run the commands from there, and then restart Node RED
have same issue when i want to install from node red pallete manage
when i want to install from pallete manager i have a big text log
the latest line in log is:
79 error gyp ERR! build error
79 error gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
79 error gyp ERR! stack at ChildProcess.<anonymous> (C:\Users\AmirGhorbani\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:209:23)
79 error gyp ERR! stack at ChildProcess.emit (node:events:514:28)
79 error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
79 error gyp ERR! System Windows_NT 10.0.19045
79 error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\AmirGhorbani\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
79 error gyp ERR! cwd C:\Users\AmirGhorbani\.node-red\node_modules\midi
79 error gyp ERR! node -v v20.10.0
79 error gyp ERR! node-gyp -v v10.0.1
79 error gyp ERR! not ok
80 verbose exit 1
If you have what is required installed (Visual Studio), you will need to raise this with the Author.
i think its same error like serial port installation
6 Jan 20:40:46 - [info] Installing module: node-red-node-serialport, version: 2.0.2
6 Jan 20:41:29 - [warn] Installation of module node-red-node-serialport failed:
6 Jan 20:41:29 - [warn] ------------------------------------------
6 Jan 20:41:29 - [warn] npm WARN config production Use `--omit=dev` instead.
npm WARN deprecated @serialport/binding-abstract@9.2.4: This package has been renamed to @serialport/bindings-interface
npm WARN deprecated @serialport/bindings@9.2.9: This package has been renamed to @serialport/bindings-cpp.
npm WARN cleanup Failed to remove some directories [
npm WARN cleanup   [
npm WARN cleanup     'C:\\Users\\AmirGhorbani\\.node-red\\node_modules\\@serialport',
npm WARN cleanup     [Error: EPERM: operation not permitted, rmdir 'C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\node_modules'] {
npm WARN cleanup       errno: -4048,
npm WARN cleanup       code: 'EPERM',
npm WARN cleanup       syscall: 'rmdir',
npm WARN cleanup       path: 'C:\\Users\\AmirGhorbani\\.node-red\\node_modules\\@serialport\\bindings\\node_modules'
npm WARN cleanup     }
npm WARN cleanup   ]
npm WARN cleanup ]
npm ERR! code 1
npm ERR! path C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings
npm ERR! command failed
npm ERR! command C:\Windows\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
npm ERR!   serialport.cpp
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan_callbacks.h(55): error C2039: 'AccessorSignature': is not a member of 'v8' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8.h(71): note: see declaration of 'v8'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan_callbacks.h(55): error C2065: 'AccessorSignature': undeclared identifier [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan_callbacks.h(55): error C2923: 'v8::Local': 'AccessorSignature' is not a valid template type argument for parameter 'T' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan_callbacks.h(55): error C2641: cannot deduce template argument for 'v8::Local' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(684): warning C4996: 'v8::Isolate::IdleNotificationDeadline': Use MemoryPressureNotification() to influence the GC schedule. [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8-isolate.h(1293): note: see declaration of 'v8::Isolate::IdleNotificationDeadline'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2955: 'v8::Local': use of class template requires template argument list [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8-local-handle.h(190): note: see declaration of 'v8::Local'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2672: 'v8::Local': no matching overloaded function found [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2783: 'v8::Local<T> v8::Local(void)': could not deduce template argument for 'T' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8-local-handle.h(192): note: see declaration of 'v8::Local'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2780: 'v8::Local<T> v8::Local(v8::Local<S>)': expects 1 arguments - 0 provided [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8-local-handle.h(195): note: see declaration of 'v8::Local'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2780: 'v8::Local<T> v8::Local(T *)': expects 1 arguments - 0 provided [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\appdata\local\node-gyp\cache\20.10.0\include\node\v8-local-handle.h(331): note: see declaration of 'v8::Local'
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2641: cannot deduce template argument for 'v8::Local' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): error C2512: 'v8::Local': no appropriate default constructor available [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2518): note: No constructor could take the source type, or constructor overload resolution was ambiguous
npm ERR! c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2544): error C2664: 'void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>,v8::AccessorNameGetterCallback,v8::AccessorNameSetterCallback,v8::Local<v8::Value>,v8::AccessControl,v8::PropertyAttribute,v8::SideEffectType,v8::SideEffectType)': cannot convert argument 2 from 'Nan::imp::NativeGetter' to 'v8::AccessorGetterCallback' [C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR!   c:\users\amirghorbani\.node-red\node_modules\nan\nan.h(2551): note: This conversion requires a reinterpret_cast, a C-style cast or function-style cast
npm ERR! prebuild-install WARN install No prebuilt binaries found (target=20.10.0 runtime=node arch=x64 libc= platform=win32)
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@10.0.1
npm ERR! gyp info using node@20.10.0 | win32 | x64
npm ERR! gyp info find Python using Python version 3.12.1 found at "C:\Python312\python.exe"
npm ERR! gyp info find VS using VS2017 (15.9.33027.88) found at:
npm ERR! gyp info find VS "C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools"
npm ERR! gyp info find VS run with --verbose for detailed information
npm ERR! gyp info spawn C:\Python312\python.exe
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args 'C:\\Users\\AmirGhorbani\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'msvs',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args 'C:\\Users\\AmirGhorbani\\.node-red\\node_modules\\@serialport\\bindings\\build\\config.gypi',
npm ERR! gyp info spawn args 'C:\\Users\\AmirGhorbani\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
npm ERR! gyp info spawn args 'C:\\Users\\AmirGhorbani\\AppData\\Local\\node-gyp\\Cache\\20.10.0\\include\\node\\common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=C:\\Users\\AmirGhorbani\\AppData\\Local\\node-gyp\\Cache\\20.10.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=C:\\Users\\AmirGhorbani\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=C:\\\\Users\\\\AmirGhorbani\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\20.10.0\\\\<(target_arch)\\\\node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=C:\\Users\\AmirGhorbani\\.node-red\\node_modules\\@serialport\\bindings',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'C:\\Users\\AmirGhorbani\\.node-red\\node_modules\\@serialport\\bindings\\build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe
npm ERR! gyp info spawn args 'build\\binding.sln',
npm ERR! gyp info spawn args '/clp:Verbosity=minimal',
npm ERR! gyp info spawn args '/nologo',
npm ERR! gyp info spawn args '/p:Configuration=Release;Platform=x64'
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (C:\Users\AmirGhorbani\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:209:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)
npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
npm ERR! gyp ERR! System Windows_NT 10.0.19045
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\AmirGhorbani\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd C:\Users\AmirGhorbani\.node-red\node_modules\@serialport\bindings
npm ERR! gyp ERR! node -v v20.10.0
npm ERR! gyp ERR! node-gyp -v v10.0.1
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in: C:\Users\AmirGhorbani\AppData\Local\npm-cache\_logs\2024-01-06T17_10_47_108Z-debug-0.log
Error: Install failed
    at C:\Users\AmirGhorbani\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\registry\lib\installer.js:285:25
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
6 Jan 20:41:29 - [error] Error: Install failed
Don't do this, you can end up with incompatible versions of modules. Luckily you did it from the wrong folder (it should have been run in C:/Users/AmirGhorbani/.node-red) so it won't have done any harm.
