Castv2-sender node
I am using castv2-sender node and it's working well to play a web stream, and controlling the volume.
Unfortunately I can't get the Stop and Pause to work.
After reading the doc I thought the payload would look something like:
    "type": "PAUSE"
But that doesn't work.
What is the exact name of the node? Something like node-red-contrib-???????
Did you check the nodes githubpage to see if it’s an issue?
@zenofmud
I actually submitted an issue on the GitHub page. It's been a few days so I was hoping that someone here had already figured it out.
And yes it is a node-red-contrib. I'm new to Node-Red, should I have posted in another category?
@zenofmud was asking which contrib node it is. Often there are several possible nodes that might be the one. Is it node-red-contrib-castv2?
and I'm an idiot.....
It is the node-red-contrib-castv2 one.
Sorry, GitHub hates to actually notify me like its supposed to. Ill take your question there.
