Catch-all in group and order of insertion
Hi There,
Yippee another nichy edge-case:
Screen Recording 2026-06-02 at 19.53.01-2
What is happening?
The function nodes are generating exceptions and the catch 1 nodes are receiving those exceptions respectively (i.e. the catch: 1 at the top catches the function 22 errors and the catch: 1 at the bottom catches the error of function 1).
The catch all in group node has the "Ignore errors handled by other Catch nodes" set in both cases meaning that since the exception is actually being handled by the catch: 1 node, then it shouldn't be receiving the exceptions. This is happening in the top group but not in the bottom group - why?
Ordering.
The bottom group was created with the catch-all node being the first exception handler in the group, the catch: 1 (for that group) was added after the catch-all node. In the top group, the order was reversed: I added the catch: 1 node to the group before adding the catch-all node.
As I said, this is an edge case that can be fixed by re-adding the catch-all node to a group once all catch-1 nodes have been added. Just have to remember to do this every time a catch-1 node is added to a group ....
I don't know whether the flow attached will maintain the error when imported but if someone can confirm, that would be great.
Tested using NR 4.0.9
[{"id":"eb24c92ce5621760","type":"tab","label":"[catch] catch all in group except those handler elsewhere","disabled":false,"info":"","env":[]},{"id":"5ea70f167d125afc","type":"group","z":"eb24c92ce5621760","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["a703aaba38a383b9","3bf38b22cdb0fa95","98023732b523561f","e846b7ff5f8f635f","350a6ead2834e85e","4897c7a025a41050"],"x":407.85716247558594,"y":525.8214364051819,"w":736.1428375244141,"h":271.46425199508667},{"id":"5ba8388e749dfa77","type":"group","z":"eb24c92ce5621760","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["023f10b500483121","bdf2557e7fc7b76f","a884ccb2f0fe0dad","76653802ad661faa","4baaef89afb5cb20","13095e53a4e7d7fc"],"x":402,"y":855,"w":773,"h":227},{"id":"a703aaba38a383b9","type":"function","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"function 22","func":"node.wrnd(\"dd\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1012.4285736083984,"y":756.2856884002686,"wires":[[]]},{"id":"3bf38b22cdb0fa95","type":"inject","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":605.2857666015625,"y":756.2856884002686,"wires":[["a703aaba38a383b9"]]},{"id":"98023732b523561f","type":"catch","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"","scope":["a703aaba38a383b9"],"uncaught":false,"x":1012.4285736083984,"y":703.4285936355591,"wires":[["350a6ead2834e85e"]]},{"id":"e846b7ff5f8f635f","type":"catch","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"catch all in group except those already dealt with","scope":"group","uncaught":true,"x":613.8571624755859,"y":566.8214364051819,"wires":[["4897c7a025a41050"]]},{"id":"023f10b500483121","type":"catch","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"catch all in group except those already dealt with","scope":"group","uncaught":true,"x":608,"y":908,"wires":[["bdf2557e7fc7b76f"]]},{"id":"bdf2557e7fc7b76f","type":"debug","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":947,"y":896,"wires":[]},{"id":"a884ccb2f0fe0dad","type":"function","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"function 1","func":"node.wrnd(\"dd\")\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1035.999984741211,"y":1041,"wires":[[]]},{"id":"76653802ad661faa","type":"inject","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":628.857177734375,"y":1041,"wires":[["a884ccb2f0fe0dad"]]},{"id":"4baaef89afb5cb20","type":"catch","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"","scope":["a884ccb2f0fe0dad"],"uncaught":false,"x":938,"y":1000,"wires":[["13095e53a4e7d7fc"]]},{"id":"13095e53a4e7d7fc","type":"debug","z":"eb24c92ce5621760","g":"5ba8388e749dfa77","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1069,"y":935,"wires":[]},{"id":"350a6ead2834e85e","type":"debug","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1038,"y":636,"wires":[]},{"id":"4897c7a025a41050","type":"debug","z":"eb24c92ce5621760","g":"5ea70f167d125afc","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":962,"y":567,"wires":[]}]
