Well as it still not very clear what you want to do with your function, we can make arbitrary examples how things can be done.
//array of objects
let mod = [{"naam":"peter", "age":5 },{"naam": "jan", "age":5 },{"naam": "klaas", "age":5 },{"naam": "pieter", "age":5 },{"naam": "miep", "age":5}];
//name to search
let targetname = "jan"
//output does not exist yet cos we don't know can we find the name
let output = null
// lets modify the array by using .map method
//https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/map
mod = mod.map(obj => {
// every object in array explored to find the target
// if naam propert has value we are searching
if(obj.naam === targetname){
obj.age ++ //lets make that person one year older (change).
output = obj // as we have success of, lets put that object to output variable
return obj
//lets write changed array to debug tab to see what just happened
node.warn('changed array: '+JSON.stringify(mod))
//as mod array is modified, you may wan to store it in context but that's another story
//context.set("mod",mod)
// send message if we have found person in array and made changes
if(output !== null){
//send changed object
msg.payload = output
// or send whole modified arrray
//msg.payload = mod
