Change color on icon
I have cleared the browser cache, restarted chrome: same as before.
I tryed Edge, same result.
I don't rememeber how I installed node-red. Followed some suggestion on internet.
Here is the start and stop of node-red:
pi@webradio:~ $ node-red-stop
Stop Node-RED
Use   node-red-start   to start Node-RED again
pi@webradio:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.153.97:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
16 Apr 19:15:06 - [info]
Welcome to Node-RED
16 Apr 19:15:06 - [info] Node-RED version: v1.3.2
16 Apr 19:15:06 - [info] Node.js  version: v14.16.1
16 Apr 19:15:06 - [info] Linux 4.19.66-v7+ arm LE
16 Apr 19:15:08 - [info] Loading palette nodes
16 Apr 19:15:10 - [info] Dashboard version 2.28.2 started at /ui
16 Apr 19:15:11 - [info] Settings file  : /home/pi/.node-red/settings.js
16 Apr 19:15:11 - [info] Context store  : 'default' [module=memory]
16 Apr 19:15:11 - [info] User directory : /home/pi/.node-red
16 Apr 19:15:11 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 Apr 19:15:11 - [info] Flows file     : /home/pi/.node-red/flows_webradio.json
16 Apr 19:15:11 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
16 Apr 19:15:11 - [info] Starting flows
16 Apr 19:15:11 - [info] Started flows
16 Apr 19:15:11 - [info] serial port /dev/ttyS0 opened at 9600 baud 8N1
16 Apr 19:15:12 - [info] [mpd-server:82f7baca.793ed8] Connected to MPD server localhost:6600
16 Apr 19:15:12 - [info] [mqtt-broker:a7459cab.67a5] Connected to broker: GPort@mqtt://localhost:1883
^C
pi@webradio:~ $
Is this not possible? ? Should I go back to backup and the old node-red ??
Can you try this approach
var k = msg.payload
if (k===0) msg = {color:"#FFFF00",bgcolor:"black",icon:"fa-4x fa-spinner fa-pulse"};
if (k===1) msg = {color:"#00FF00",bgcolor:"black",icon:"fa-4x fa-download"};
if (k===2) msg = {color:"#FF0000",bgcolor:"black",icon:"fa-4x fa-upload"};
if (k===3) msg = {color:"#FF0000",bgcolor:"black",icon:"fa-4x fa-exclamation-triangle"};
/*  0=moving
    1=closed
    2=opened
    3=error   */
msg.payload = k;
No need to change anything else but the contents of the function node.
It is not about like I know whats wrong but I have such methods running flawlessly years now so worth of try.
Maybe the ui_control only in message behaves not so nice for possible socket losses and re-connections.
The log looks as it should, no clues as to why the dashboard tab is missing. Can you check in the developer console in your browser to see if it shows any errors?
I will try check in the developer console in the browser!
hotNipi your solution seems to work!! But I leave it till tomorrow and try then. Just to be 100%.
Now I have increased hope!!
Thank you for taking your time! ! !
hotNipi Sorry! Not better!
I have taken this out of developer consol in browser:
WARN:
app.min.js:150
You are using the ngTouch module.
AngularJS Material already has mobile click, tap, and swipe support...
ngTouch is not supported with AngularJS Material!
FAIL:
:1880/ui/loading.html:1
Failed to load resource: the server responded with a status of 404 (Not Found)
FAIL:
app.min.js:150
SideNav 'left' is not available! Did you use md-component-id='left'?
(anonymous) @ app.min.js:150
FAIL:
:1880/ui/socket.io/?EIO=3&transport=polling&t=NZUnBot:1
Failed to load resource: net::ERR_NETWORK_CHANGED
WARN:
DevTools failed to load SourceMap: Could not load content for http://192.168.153.97:1880/ui/js/angular-chart.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
I don't understand it, but someone perhaps can give me a clue, hopefully!
edit: Now the icon does not change either, but if I change "flow" in the left menu back and forth, then have the icon changed??!
I think that suggests there is something odd about the network connection between the PC and the Pi. How are they connected? Are they on the same local network?
In a terminal on the Pi what does this command show?
ip addr
They are connected in the same local network.Both my PC and Pi are connected with cable. The Pi has static adress.
pi@webradio:~ $ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:38:64:10 brd ff:ff:ff:ff:ff:ff
inet 192.168.153.97/16 brd 192.168.255.255 scope global eth0
inet6 fe80::49a7:3642:3a53:d8b6/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:6d:31:45 brd ff:ff:ff:ff:ff:ff
Sorry, I am out of ideas on the missing dashboard tab. Hopefully someone else can help.
One more idea actually, have you got another machine on the network you can try to see if that one can see it?
I tryed my mobile PC: same!
Colin: Thank you for spending time with my issue.
Ghosts ? ? ?
Now I got "dashbord" in the dropdown menu ! ? ! ?
I chosed "dashboard", "site", "option" sade "click to show side menu". I chosed "Alwayes show side menu". Deploy. and chosed "click to show side menu". And I am back!!
What did you do that made it reappear?
I took another Pi and copy the simulator-flow to the "new" Pi. Where it works !! ! (Node-red v1.2.7). This hade the "dashboard" in the dropdown menu. When I go back to the first Pi, there it was, in the dropdown menu.
Ghosts ? ! ? I don't believe in ghosts! Or?
Edit: The "new" Pi is running "Buster"
Probably it will remain one of the great unsolved mysteries of life.
Probably !
