Change Dashboard side on click on image
So I managed to show an image on the dashboard using a template node andnthe following code
<div height="200" style="height: 200px;">
<img src="/Block_Gray.png" width="140"><br/>
</div>
Now I want to send a number to a ui control node, when the image is clicked. I already tried the following line
<a href="" class="off" onclick="this.className='on';return false;">Foo</a>
Does somebody have a hint for me?
The hint you need is the ‘Sending a message’ section of the ui_template node’s help in the Info sidebar.
I saw the Sending a message section, but this creates an extra button under the image, that needs to be clicked. I don’t want to creat a button, I wnat to capture if the image is clicked.
Understood, but the principle is the same. That section shows how to trigger a message when something happens using the ng-click attribute.
Applying that to your <div>…
<div height="200" style="height: 200px;" ng-click="send({payload:'clicked'});">
</div>
Thanks, worked for me
